MiniDSP C-DSP 6x8 Audio Processor USB 28/56bit 6 to 8 channels
By buying this product you get 34 loyalty points
Reference : 10368
345,00 €tax incl.
287,50 € tax excl.
This powerful DSP can both serve as an active multi-channel filter, processor, 6-band parametric equalizer, source mixer, and DAC / ADC.
It has 2 digital inputs, 4 analogue inputs and 8 asymmetrical analog outputs.
Combined with a software plug-in via USB-B, it is possible to configure real-time audio processing filters from a PC or Mac.
Once the device is configured, the device operates autonomously and therefore does not require the use of a computer.
MiniDSP C-DSP 6x8 User's Manual
Presentation of the MiniDSP C-DSP 6x8
Features:/ Strong>
  • DSP ADAU1445 172MHz, 28 / 56bit
  • Sampling rate: ADC / DAC 24bit 48kHz
  • Internal processing sampling rate: 48kHz
  • Control interface without driver USB 2.0 compatible Windows / Mac OS
  • S / PDIF RCA Digital Input
  • Asymmetric inputs: Balanced or RCA terminals
  • Unbalanced outputs: RCA
  • Noise signal ratio DAC: 110dB
  • Input signal max. RCA: 2Vrms (8 dBu) asymmetrical
  • Input signal max. Terminal Blocks: 4Vrms (14 dBu) asymmetrical or 8Vrms (20dBu) symmetrical
  • Output signal max. RCA: 2Vrms (8 dBu) asymmetrical
  • RJ45 port to connect a remote control (supplied)
  • MicroSD card slot (software update)
  • Power supply 12V DC via terminal blocks (DC-DC power supply)
  • USB 2.0 port
  • Dimensions: 41 x 205 x 122mm
Are delivered:/ Strong>
  • 1x USB-B cable
  • 1x remote control
  • 1x Remote control cable 1.5m
https://www.audiophonics.fr/images2/8869/miniDSP2x8_kit_3.jpg
InputScrew terminals
Max sampling rate48kHz
