MiniDSP Kit 2x8 Audio Processor 26 / 56bit 2 to 8 channels
By buying this product you get 36 loyalty points
Reference : 8869
369,00 €tax incl.
307,50 € tax excl.
This powerful DSP can serve both as an active multi-channel filter, processor, equalizer, source mixer, ADC and DAC converter.
It has 2 analogue inputs and 8 balanced and unbalanced analog outputs.
It is possible to add digital inputs by connecting a card miniDSP DIGI-FP on the I2S input.
Combined with a software plug-in, it is possible to configure real-time audio processing filters from a PC or Mac.
Once the card is configured, the device operates autonomously and therefore does not require the use of a computer.
This product is compatible with our remote control: fiche 10901
Review on HifiZine
https://www.audiophonics.fr/images2/8869/hifizine.jpg
MiniDSP 2x8 User's Manual
Plug-in documentation for the MiniDSP 2x8
Introducing the MiniDSP 2x8
Features:/ Strong>
  • 172MHz, 28 / 56bit
  • 24bit ADC / DAC
  • 96kHz sample rate
  • Control interface without driver USB 2.0 compatible Windows / Mac OS
  • Asymmetric inputs: Balanced or RCA terminals
  • Unbalanced outputs: Balanced or RCA terminals
  • Sampling rate: ADC 24bits - DAC 48 / 96kHz
  • ADC / DAC Noise Ratio: 114dB
  • Input signal max. RCA: 2Vrms (8 dBu) asymmetrical
  • Input signal max. Terminal Blocks: 4Vrms (14 dBu) asymmetrical or 8Vrms (20dBu) symmetrical
  • Output signal max. RCA: 2Vrms (8 dBu) asymmetrical
  • Output signal max. Terminal Blocks: 4Vrms (14 dBu) asymmetrical or 8Vrms (20dBu) symmetrical
  • Dip Switch output control 6dB attenuation on outputs by Dip Switch control
  • Infrared Receiver
  • Extention I2S compatible with miniDIGI I / O card (SPDIF / Toslink / AES)
  • Power supply: 12Vdc, 18W
  • Remote IN / OUT(Trigger) Turns off power with a delay to avoid plops
  • USB: Mini-USB connector and standard 5pin connector
  • Dimensions: 30 x 200 x 250mm
Are delivered:/ Strong>
  • 1 x mini-USB cable
  • 1 x power supply 12V 3A + DC connector
  • Screw terminals for inputs and outputs
DOWNLOAD A FREE PLUG-IN FOR THE MINIDSP 2X8:
For a full use of your MiniDSP product, it is necessary to have a plug-in.
There are several plug-ins available for download right here.
When receiving the product, you will receive in your package the method to follow to download the plug-in of your choice free of charge.
https://www.audiophonics.fr/images2/8869/miniDSP2x8_kit_1.jpg
https://www.audiophonics.fr/images2/8869/miniDSP2x8_kit_2.jpg
https://www.audiophonics.fr/images2/8869/miniDSP2x8_kit_3.jpg
https://www.audiophonics.fr/images2/8869/miniDSP2x8_kit_4.jpg
Input
  • RCA
  • Screw terminals
Output
  • RCA
  • Screw terminals
Max sampling rate
  • 96kHz
Color
  • Blue
