WONDOM DB-DP11219 SigmaStudio Programmer Board for Sure DSP
Wondom offers a programming card compatible with Sure brand DSPs. This module is essential for programming the DSP and managing the desired signal processing. Working with the free software SigmaStudio, this one will allow you thanks to a graphic interface to adapt the treatment carried out by your DSP. For this the module connects to the PC simply via Micro USB cable and to the DSP via cables with supplied jumpers.
4.6 / 5
Reference : 12245
19,90 €tax incl.
16,58 € tax excl.
Shipping date: 22-04-2025.
Wondom Programmer for DSP Sure
SigmaStudio Programming Module for Sure DSP
Download the user manual here.
Procedure to install the USBi driver (for 64bit Windows systems):
  • Download and install Sigma Studio on your PC.
  • In the Sigma Studio installation directory, go to the USB Drivers> x64 folder
  • The installation of USBi drivers is launched by double clicking on the file DPinst.exe
  • Once the installation is completed, the module can be used
Check the driver installation:
  • The module must be connected to the PC
  • Open the Windows Device Manager and then the "USB Bus Controllers" node
  • The device is displayed as "Analog Devices USBI (programmed)" if the driver has been installed correctly
Functional test :
  • Launch the Sigma Studio software with the connected module
  • Open the demo file ( available here ) in Sigma Studio
  • In the project window, select "Hardware configuration"
  • The "USB" field is highlighted in green. By pressing the reset button on the module, the field should briefly change to red.
Audiophonics does not provide technical support for using the SigmaStudio software.
Sigma Studio User Guide
Find on our blog a complete guide to discover the features of Sigma Studio software and learn how to use it to make an effective correction to your system.
Tutoriel Sigma Studio
Tutorial
PC ConnectionVia Micro USB
Connection to the Sure DSP moduleVia cables with jumpers
CompatibilitySure DSP Module
Accessories deliveredConnection cables
wondom-module-de-programmation-sigmastud
OutputPCB Connector
5 reviews
Très bien
Fonctionne parfaitement avec Sigma Studio. Une étoile en moins car il faut connecter la carte de programmation à l'ordinateur puis connecter le DSP à la carte de programmation pour voir apparaitre le bon driver dans le gestionnaire de périphérique.
This review has been posted for WONDOM DB-DP11219 SigmaStudio Programmer Board for Sure DSP
Marche plutôt bien.
Au cas ou vous galérez pour faire correctement reconnaître la carte par Windows même après 15000 installations des drivers :
AVANT d'y connecter le DSP
Branchez la carte à l'ordinateur, ouvrez sigmaStudio et établissez la connexion .
Après, ça fonctionne nikel.
Je ne met que 4 étoiles car sauf erreur de ma part, ce détail n'est mentionné dans aucune doc officielle de la marque.
Audiophonics Rocks
Best in class, got it delivered to India. Still not tested yet, but hope to do it soon!
interface compacte
C'est petit et ça fonctionne bien sur mes 2 pc portables sous windows 7 et 10 en usb 2 et 3 (programmation d'un ADAU1701 wondom). Merci à Audiophonics pour la page de blog avec guide détaillé d'installation de Sigma studio, dans mon cas il fallait effectivement installer les pilotes séparément pour que le module soit reconnu.
Parfait
Permet de programmer les modules WONDOM grâce au logiciel SigmaStudio ! Pour avoir le fichier démo il faut aller dans la rubrique téléchargement ;)
Wondom offers a programming card compatible with Sure brand DSPs. This module is essential for programming the DSP and managing the desired signal...
