This programming module allows you to define in detail the DSP features of your Sure devices. It offers a simplified way of using bluetooth and accessible from a smartphone application.
Set the DSP of your Sure devices (JAB3)
Attention, once your microcontroller has been programmed using the ICP3 module, it is no longer possible to return to the factory settings. (This tool overides the factory settings)
This programming module allows you to define in detail the DSP features of your Sure devices. It offers a simplified way of using bluetooth and accessible from a smartphone application. This tool makes it very easy and quick to configure the volume, gain, filters, stereo delay, phase and equalizer of the micro-controller.
To set your Sure DSPs via Bluetooth, first get the MIUMAX app. It is free and available on Android and IOS platforms.
Mettez le sélecteur situé sur l'extrémité du module sur la position 2 (REMOTE)
A second more complete method allows to program in depth the microcontroller through SigmaStudio software (available here)
When connected to a PC via its micro-USB port, the WONDOM programmer also offers an extremely complete DSP programming interface with SigmaStudio. This solution offers a wide range of audio tools: equalizer, cross-over, bass enhancement, dynamic multi-band processor, delay compensation, speaker compensation, stereo adjustments ...
Caution: Audiophonics does not provide technical support regarding the use of SigmaStudio software.
Find on our blog a complete guide to discover the features of Sigma Studio software and learn how to use it to make an effective correction to your system.
Type | Programmation module for Sure DSP |
Power supply | Micro-USB |
Input | Micro-USB / Bluetooth |
Output | 6 pin programming cable (included) |
Dimensions | 50 x 51 mm |
Entraxe | 42 x 42 mm |
Weight | 18 g |
Software compatibility | SigmaStudio (Windows) MIUMAX (IOS / Android) |
