MINIDSP C-DSP 8x12 DL Audio Processor DSP Dirac Live SHARC ADSP21489 12 Channels
The MiniDSP C-DSP 8x12DL is a high-end audio processor that will allow you to enjoy the full potential of your audio system, including a Car Audio system since the DSP has features that allow it to be used in this context.
By buying this product you get 114 loyalty points
Reference : 13869
1 149,00 €tax incl.
957,50 € tax excl.
MiniDSP C-DSP 8x12 DL
MiniDSP C-DSP 8x12 DL Processeur Audio DSP Dirac Live SHARC ADSP21489 12 Canaux
The MiniDSP C-DSP 8x12DL is a high-end audio processor that will allow you to enjoy the full potential of your audio system, including a Car Audio system since the DSP has features that allow it to be used in this context. It includes a Dirac Live acoustic correction system and a SHARC ADSP21489 400MHz floating point processing chip. Its 32bit AKM converters provide a THD+N of -107dB for an incredibly accurate sound reproduction. Its intuitive input/output system consists of six low-level analog inputs for extremely low noise level, six high level inputs as well as an optical and a coaxial input. On the output side, the device offers 12 RCA, which, combined with eight-channel Dirac Live processing, make the C-DSP 8x12 DL particularly suitable for active crossover systems or surround/multichannel installations with subwoofer integration.
This DSP also includes a complete, efficient and intuitive audio processing system: equalizers, compression, delay adjustment, crossovers up to 48dB/octave and a mixing matrix with rear/center management are available to allow you to make precise adjustments to your audio system. Up to 4 profiles can be stored in the DSP's flash memory and can be easily selected using a wired or infrared remote control.
For Car Audio use, the C-DSP 8x12DL includes an isolated power supply, trigger input/output, wired remote control for dashboard mounting and a Micro SD card slot for offline device configuration.
Product typeDSP
DSP ChipAnalog Devices ADSP21489 400MHz floating point DSP
DAC ChipAK4456
ADC ChipAK5556
THD+N0.0007%
SNR115dB
Input / Output configuration8 inputs / 12 outputs
Inputs6x High level inputs
6x Single-ended low level RCA inputs
1x S/PDIF Coaxial
1x Optical Toslink
ASRC sampling rate44.1kHz - 192kHz
Outputs12x RCA
RCA outputs SNR115dB
RCA outputs THD+N0.0007%
Max input level8 or 12Vrms on high level inputs
4 or 2Vrms on low level inputs
Max output level6Vrms
Input impedanceHigh level : 68Ω
Low level : 10kΩ
Output impedance560Ω
Calibration softwarePlugin C-DSP 8x12
Filtering technologyIIR / FIR depending on plugin
Number of presets4
Impulse response correction
Infrared remote learning
Windows / Mac compatibility
Room EQ Wizard support
Dimensions41 x 205 x 122mm
Housing materialAluminium
Package1x MiniDSP C-DSP 8x12 DL
1x Dirac Live license
1x USB cable 1m
1x Remote control module + remote control cable 5m
1x C-DSP 8x12 DL plugin license
1x Control GUI plugin
Input
  • Optical
  • RCA
  • SPDIF
Output
  • RCA
Max sampling rate
  • 192kHz
Color
  • Black
Très complet
Maintenant j'ai dans un seul boîtier la gestion des entrées (tos link stéréo ou 5.1 analogique),la gestion bass management, le dirac live en 5.2, et la gestions du filtrage actif des 12 hp ! Il manque juste par rapport a l'ancienne gamme mini dsp les compresseurs sur les sorties ont disparu et les filtres du bass management sont en 24db au lieu de 48db comme les crossovers de sortie. Au final un tres bon produit pour mon usage !
This review has been posted for MINIDSP C-DSP 8x12 DL Audio Processor DSP Dirac Live SHARC ADSP21489 12 Channels
The MiniDSP C-DSP 8x12DL is a high-end audio processor that will allow you to enjoy the full potential of your audio system, including a Car Audio...
