JANTZEN AUDIO ELECAP Electrolytic Capacitor 100V 270µF 5%
Jantzen Audio EleCap electrolytic capacitors are non-polarized aluminum capacitors using etched or "raw" foil. With a tolerance of ±5%, they are more accurate than most other standard electrolytic capacitors.
Reference : 15484
5,50 €tax incl.
4,58 € tax excl.
Shipping date: 16-07-2024.
Jantzen Audio EleCap Condensateur Électrolytique 100V 270µF 5%
Jantzen Audio EleCap electrolytic capacitors are non-polarized aluminum capacitors using etched or "raw" foil. With a tolerance of ±5%, they are more accurate than most other standard electrolytic capacitors, often with a tolerance of ±10%. Both affordable and versatile, they are an excellent choice especially for bass channels or for integration into a crossover with limited space.
Product typeElectrolytic capacitor
Rated voltage100VDC
35VAC
Capacitance270µF
Tolerance±5%
Operating temperature range-40°C / +85°C
Leakage current< 0.003CRUR (µA)
Dissipation factor< 0.1 @ 1kHz
Signal directionNon polarized (bi-polar capacitor)
ESR max.0.07Ω
Dimensions16x34mm
Weight11g
Tolerance (%)5.0
Capacitor capacitance270
Rated voltage (V)100.0
Capacitor typeElectrolytic capacitor
Capacitor formatAxial
Jantzen Audio EleCap electrolytic capacitors are non-polarized aluminum capacitors using etched or "raw" foil. With a tolerance of...
