Electronic components and tools
DENIS B.
DENAFRIPS ENYO DAC R2R
Commande sans aucun problème merci
Henrik H.
Good with moderate volume, after correction.
Bought 2 for simracing(under chair), but then I tried it with some music, and I use them for that since almost every day.
I...
Henrik H.
Does its job.
Bought it for BST-1 bass shakers, (simracing/music) but it was too weak for them, so I use it for smaller (15W) exciters now...
Need electronic components or tools to complete a project? You are at the right place! This category contains all our electronic components but also specific tools for your realizations.
  • Tools workshop
    Tools workshop
    Tools workshop
  • Audio Transformer
    Audio Transformer
  • Tubes and lamps
    Tubes and lamps
    Discover our wide range of tubes and lamps, adapted to an audio use, whether it is for the design of an amplifier or preamplifier, or to make a replacement of a defective model.
  • Electronic components
  • Screws and bolts
    Screws and bolts
  • Connectors for PCB
    Connectors for PCB
