Audio Transformer E-9912 600:10K (Unit)
This E-9912 600:10k permalloy transformer can be used for a wide range of applications. It can be used, for example, to convert a balanced signal into an unbalanced one and vice versa, or to isolate an audio signal from the other circuit, avoiding unwanted noise generated by the circuit itself.
Reference : 19128
19,90 €tax incl.
16,58 € tax excl.
Shipping date: 23-04-2025.
Audio Transformer E-9818 600:10K : Front view
This E-9912 600:10k permalloy transformer can be used for a wide range of applications. It can be used, for example, to convert a balanced signal into an unbalanced one and vice versa, or to isolate an audio signal from the other circuit, avoiding unwanted noise generated by the circuit itself. With its near-perfect decibel variation of just +/-0.18 dB over a frequency range from 20Hz to 20kHz, you can rely on this transformer to deliver Hi-fi quality. Furthermore, the E-9912 600:10k transformer comes with its own PCB, to ensure compatibility with the system in which it will be installed.
Audio Transformer E-9818 600:10K: Electrical diagram
Product typeAudio transformer
Transformation ratio1:1
Spacing betwen pins6mm
Spacing between rows of pins13.5mm
Inductance between the two coils≥ 20H
Loss across transformer+/-0.18 dB
Dimensions20 mm x 20mm x 18.3mm
Weight28g
Package1x Audio Transformer E-9912 600:10K
1x Compatible PCB
This E-9912 600:10k permalloy transformer can be used for a wide range of applications. It can be used, for example, to convert a balanced signal...
