OYAIDE NRF-005T Noise Suppressor Adhesive Tape Pulshut 4m
Oyaide NRF-005T is a noise suppression tape using PULSHUT® (high performance non-woven textile) material developed by Asahi Kasei Corporation. This is a revolutionary material for suppressing electromagnetic noise and radiation generated by AV equipment and cables, allowing for more transparent sound reproduction.
4.3 / 5
Reference : 17156
119,00 €tax incl.
99,17 € tax excl.
Shipping date: 23-04-2025.
Oyaide NRF-005T
Oyaide NRF-005T Ruban adhésif suppresseur de bruit Pulshut 4m
Oyaide NRF-005T is a noise suppression tape using PULSHUT® (high performance non-woven textile) material developed by Asahi Kasei Corporation. This is a revolutionary material for suppressing electromagnetic noise and radiation generated by AV equipment and cables, allowing for more transparent sound reproduction. It also uses no magnetic elements. With a thickness of only 0.05mm, the NRF-005T offers great flexibility for convenient installation on any surface. It is easy to use, as the NRF-005T is simply snapped onto areas of the audio/video equipment or cable that are likely to produce noise.
Product typeNoise suppressor adhesive tape
MaterialPulshut®
Adhesive surfaceAcrylic
Tape width15mm
Tape thickness~ 0.11mm (base material: 0.05mm + adhesive: 0.06mm)
Density0.8g/cm³
Surface resistance≥ 1.0*10^12Ω/cm
Volume resistivity≥ 1.0*10^12Ω/cm
Tension3.5kgf/cm³
Operating temperature range-20°C / +90°C
Environmental certificationsRoHS
REACH
Sans halogène
Quantity4m
3 reviews
Faut juste ne pas en mettre de trop.
Cordons secteur sans blindage? Un pourtour de ce produit cote recepteur et le tour est joue.
This review has been posted for OYAIDE NRF-005T Noise Suppressor Adhesive Tape Pulshut 4m
utile ou pas ?
Personnellement, je n'ai pas noté d'amélioration concrète ou audible avec ce produit
completely transcendental deductive stuff
i was somehow inspired by a *zoviet-france* picture...highest recommendation if you're into maniac options or prone to sensitive side-effects...i will ask my japanese friends to make an aroma-diffuser version...seriously, it is the most low cost highly adaptable detail (together with the furutech nano liquid)
thanks to audiophonics people for their excellent prestation, as usual
Oyaide NRF-005T is a noise suppression tape using PULSHUT® (high performance non-woven textile) material developed by Asahi Kasei...
