Tolerance (%)
0 % - 20 %
Capacitor capacitance (µF)
Capacitor format
Capacitor type
Inductance (mh)
Material
Power (W)
0 - 250
Rated voltage (V)
Input voltage (V)
V
V
Output voltage (V)
Output current (A)
0 A - 5 A
Rated current (A)
Resistance (Ohm)
Section (mm²)
0 mm - 1 mm
Channel
Screw thread length (mm)
Screw thread
Color
Electronic components
David T.
Je suis parti pendant trois jours, j ai oublié D éteindre l amplificateur....
La précision sonore de cet appareil est...
Eemeli T.
Good overall quality
Bought these to replace Norsone Arran RCA cables. The quality seems very good - the cord is quite flexible and covered with...
Eemeli T.
Does the job
Works as supposed - simple and easy to use as atrigger device. There are a couple of setbacks, though - the device is quite...
  • Capacitors
    Capacitors
  • Selfs & Coils
    Selfs & Coils
  • Resistors
    Resistors
  • Potentiometers
    Potentiometers
  • Selectors
    Selectors
  • OPA Adapters
    OPA Adapters
  • Universal circuit boards
  • Relays
    Relays
  • Fuse and Circuit breaker
  • OPA
    OPA
  • Transistors
    Transistors
  • Speaker L-control
    Speaker L-control
  • Voltage Regulator
    Voltage Regulator
  • Clocks
    Clocks
  • Light Bulbs and LED
    Light Bulbs and LED
  • Tubes and lamps
    Tubes and lamps
  • Audio Transformer
    Audio Transformer
  • Ref : 5719
    Air coils, for physical reasons, are unbeatable in terms of precision on the restitution of the impulses, and are free of any distortion (contrary to ferrite coils). For this reason, Mundorf produces coils with a large wire diameter for purists. It is therefore possible to achieve better inductances while maintaining low internal impedance and zero...
    18,90 € 15,75 €Ex.
    In Stock
  • Ref : 5717
    In Stock
    24,90 € 20,75 €Ex.
    In Stock
  • Ref : 5721
    In Stock
    29,90 € 24,92 €Ex.
    In Stock
  • Ref : 5722
    In Stock
    27,90 € 23,25 €Ex.
    In Stock
  • Ref : 5720
    15,70 € 13,08 €Ex.
    In Stock
  • Ref : 5723
    In Stock
    35,90 € 29,92 €Ex.
    In Stock
  • Ref : 4196
    In Stock
    Air coils, for physical reasons, are unbeatable in terms of precision on the restitution of the impulses, and are free of any distortion. For this reason, Mundorf produces coils with a large wire diameter for purists. It is therefore possible to achieve better inductances while maintaining low internal impedance and zero distortion.
    13,90 € 11,58 €Ex.
    In Stock
  • Ref : 4197
    In Stock
    12,90 € 10,75 €Ex.
    In Stock
  • Ref : 4198
    In Stock
    13,90 € 11,58 €Ex.
    In Stock
  • Ref : 4195
    In Stock
    11,90 € 9,92 €Ex.
    In Stock
  • Ref : 4199
    In Stock
    12,90 € 10,75 €Ex.
    In Stock
  • Ref : 4200
    In Stock
    14,90 € 12,42 €Ex.
    In Stock
  • Ref : 4201
    In Stock
    19,90 € 16,58 €Ex.
    In Stock
  • Ref : 4202
    In Stock
    20,90 € 17,42 €Ex.
    In Stock
  • Ref : 4203
    19,90 € 16,58 €Ex.
    In Stock
  • Ref : 4204
    In Stock
    24,90 € 20,75 €Ex.
    In Stock
  • Ref : 4205
    In Stock
    22,90 € 19,08 €Ex.
    In Stock
  • Ref : 4206
    24,90 € 20,75 €Ex.
    In Stock
  • Ref : 4208
    In Stock
    39,90 € 33,25 €Ex.
    In Stock
  • Ref : 4209
    In Stock
    39,90 € 33,25 €Ex.
    In Stock
  • Ref : 4210
    In Stock
    43,90 € 36,58 €Ex.
    In Stock
  • Ref : 4222
    79,00 € 65,83 €Ex.
    In Stock
  • Ref : 4207
    In Stock
    31,90 € 26,58 €Ex.
    In Stock
  • Ref : 4212
    In Stock
    39,90 € 33,25 €Ex.
    In Stock
  • Ref : 4213
    In Stock
    52,90 € 44,08 €Ex.
    In Stock
  • Ref : 4211
    In Stock
    47,90 € 39,92 €Ex.
    In Stock
  • Ref : 4215
    In Stock
    39,90 € 33,25 €Ex.
    In Stock
  • Ref : 4216
    62,90 € 52,42 €Ex.
    In Stock
  • Ref : 4214
    In Stock
    52,90 € 44,08 €Ex.
    In Stock
  • Ref : 4217
    In Stock
    59,90 € 49,92 €Ex.
    In Stock
  • Ref : 4218
    In Stock
    79,00 € 65,83 €Ex.
    In Stock
  • Ref : 4219
    In Stock
    75,00 € 62,50 €Ex.
    In Stock
  • Ref : 4220
    In Stock
    99,00 € 82,50 €Ex.
    In Stock
  • Ref : 4974
    In Stock
    Mundorf BS100 coils are high performance models for low frequency filtering. The core is made of Feron which is heat treated after production. This treatment gives it an optimal internal structure for good magnetic characteristics with very low losses and low distortion.
    26,90 € 22,42 €Ex.
    In Stock
  • Ref : 4975
    In Stock
    27,90 € 23,25 €Ex.
    In Stock
  • Ref : 4987
    In Stock
    34,90 € 29,08 €Ex.
    In Stock
  • Ref : 4988
    In Stock
    44,90 € 37,42 €Ex.
    In Stock
  • Ref : 4978
    In Stock
    25,50 € 21,25 €Ex.
    In Stock
  • Ref : 4977
    In Stock
    25,00 € 20,83 €Ex.
    In Stock
  • Ref : 4981
    In Stock
    27,40 € 22,83 €Ex.
    In Stock
