Tolerance (%)
0 % - 20 %
Capacitor capacitance (µF)
Capacitor format
Capacitor type
Inductance (mh)
Power (W)
0 - 250
Rated voltage (V)
Input voltage (V)
V
V
Output voltage (V)
Output current (A)
0 A - 5 A
Rated current (A)
Resistance (Ohm)
Section (mm²)
0 mm - 1 mm
Contacts number
7 - 9
Channel
Color
Electronic components
Francois W.
Excellent ampli
J'ai ajouté cet ampli FX audio associé avec mes Bose acoustimass 5 série 3, le son est nickel, dynamique, pas agressivite...
Christian C.
le couteau suisse
Cet appareil m'avait été recommandé par un ami suite à un problème avec ma carte son. Cet appareil est très simple...
Jean-Michel j.
TRES BON TUBES
Monté a la place des Electro-harmonix sur le JADIS JA 200 avec les psavanes enECC82 (car je n'ai pas trouvé de ECC82...
  • Capacitors
    Capacitors
  • Selfs & Coils
    Selfs & Coils
  • Resistors
    Resistors
  • Potentiometers
    Potentiometers
  • Selectors
    Selectors
  • OPA Adapters
    OPA Adapters
  • Universal circuit boards
  • Relays
    Relays
  • Fuse and Circuit breaker
  • OPA
    OPA
  • Transistors
    Transistors
  • Speaker L-control
    Speaker L-control
  • Voltage Regulator
    Voltage Regulator
  • Clocks
    Clocks
  • Light Bulbs and LED
    Light Bulbs and LED
  • Tubes and lamps
    Tubes and lamps
  • Audio Transformer
    Audio Transformer
  • Ref : 5720
    Air coils, for physical reasons, are unbeatable in terms of precision on the restitution of the impulses, and are free of any distortion (contrary to ferrite coils). For this reason, Mundorf produces coils with a large wire diameter for purists. It is therefore possible to achieve better inductances while maintaining low internal impedance and zero...
    15,70 € 13,08 €Ex.
    In Stock
  • Ref : 5723
    In Stock
    35,90 € 29,92 €Ex.
    In Stock
  • Ref : 4196
    In Stock
    Air coils, for physical reasons, are unbeatable in terms of precision on the restitution of the impulses, and are free of any distortion. For this reason, Mundorf produces coils with a large wire diameter for purists. It is therefore possible to achieve better inductances while maintaining low internal impedance and zero distortion.
    13,90 € 11,58 €Ex.
    In Stock
  • Ref : 4197
    In Stock
    12,90 € 10,75 €Ex.
    In Stock
  • Ref : 4198
    In Stock
    13,90 € 11,58 €Ex.
    In Stock
  • Ref : 4195
    In Stock
    11,90 € 9,92 €Ex.
    In Stock
  • Ref : 4199
    In Stock
    12,90 € 10,75 €Ex.
    In Stock
  • Ref : 4200
    In Stock
    14,90 € 12,42 €Ex.
    In Stock
  • Ref : 4201
    In Stock
    19,90 € 16,58 €Ex.
    In Stock
  • Ref : 4202
    In Stock
    20,90 € 17,42 €Ex.
    In Stock
  • Ref : 4203
    19,90 € 16,58 €Ex.
    In Stock
  • Ref : 4204
    In Stock
    24,90 € 20,75 €Ex.
    In Stock
  • Ref : 4205
    In Stock
    23,90 € 19,92 €Ex.
    In Stock
  • Ref : 4206
    24,90 € 20,75 €Ex.
    In Stock
  • Ref : 4208
    In Stock
    39,90 € 33,25 €Ex.
    In Stock
  • Ref : 4209
    In Stock
    39,90 € 33,25 €Ex.
    In Stock
  • Ref : 4210
    In Stock
    43,90 € 36,58 €Ex.
    In Stock
  • Ref : 4222
    79,00 € 65,83 €Ex.
    In Stock
  • Ref : 4207
    In Stock
    31,90 € 26,58 €Ex.
    In Stock
  • Ref : 4212
    In Stock
    39,90 € 33,25 €Ex.
    In Stock
  • Ref : 4213
    In Stock
    52,90 € 44,08 €Ex.
    In Stock
  • Ref : 4211
    In Stock
    47,90 € 39,92 €Ex.
    In Stock
  • Ref : 4215
    In Stock
    39,90 € 33,25 €Ex.
    In Stock
  • Ref : 4216
    In Stock
    79,90 € 66,58 €Ex.
    In Stock
  • Ref : 4214
    In Stock
    52,90 € 44,08 €Ex.
    In Stock
  • Ref : 4217
    In Stock
    59,90 € 49,92 €Ex.
    In Stock
  • Ref : 4218
    In Stock
    79,00 € 65,83 €Ex.
    In Stock
  • Ref : 4219
    In Stock
    75,00 € 62,50 €Ex.
    In Stock
  • Ref : 4220
    In Stock
    99,00 € 82,50 €Ex.
    In Stock
  • Ref : 4974
    In Stock
    Mundorf BS100 coils are high performance models for low frequency filtering. The core is made of Feron which is heat treated after production. This treatment gives it an optimal internal structure for good magnetic characteristics with very low losses and low distortion.
    26,90 € 22,42 €Ex.
    In Stock
  • Ref : 4975
    In Stock
    27,90 € 23,25 €Ex.
    In Stock
  • Ref : 4987
    In Stock
    34,90 € 29,08 €Ex.
    In Stock
  • Ref : 4988
    In Stock
    44,90 € 37,42 €Ex.
    In Stock
  • Ref : 4978
    In Stock
    25,50 € 21,25 €Ex.
    In Stock
  • Ref : 4977
    In Stock
    25,00 € 20,83 €Ex.
    In Stock
  • Ref : 4981
    In Stock
    27,40 € 22,83 €Ex.
    In Stock
  • Ref : 2752
    In Stock
    Mundorf BS140 coils are high performance models for low frequency filtering. The core is made of Feron which is heat treated after production. This treatment gives it an optimal internal structure for good magnetic characteristics with very low losses and low distortion.
    34,90 € 29,08 €Ex.
    In Stock
  • Ref : 2753
    In Stock
    34,90 € 29,08 €Ex.
    In Stock
  • Ref : 6118
    In Stock
    62,90 € 52,42 €Ex.
    In Stock
  • Ref : 2765
    In Stock
    60,90 € 50,75 €Ex.
    In Stock
