Tolerance (%)
0 % - 20 %
Capacitor capacitance (µF)
Capacitor format
Capacitor type
Inductance (mh)
Power (W)
0 - 250
Rated voltage (V)
Input voltage (V)
V
V
Output voltage (V)
Output current (A)
0 A - 5 A
Rated current (A)
Resistance (Ohm)
Section (mm²)
0 mm - 1 mm
Contacts number
7 - 9
Channel
Color
Electronic components
Markus W.
Good quality
These binding posts are very cost-effective. Build quality is massive contrary to most of the comparable products in this price...
Patrick v.
Magnifiques !
Tom K.
  • Capacitors
    Capacitors
  • Selfs & Coils
    Selfs & Coils
  • Resistors
    Resistors
  • Potentiometers
    Potentiometers
  • Selectors
    Selectors
  • OPA Adapters
    OPA Adapters
  • Universal circuit boards
  • Relays
    Relays
  • Fuse and Circuit breaker
  • OPA
    OPA
  • Transistors
    Transistors
  • Speaker L-control
    Speaker L-control
  • Voltage Regulator
    Voltage Regulator
  • Clocks
    Clocks
  • Light Bulbs and LED
    Light Bulbs and LED
  • Tubes and lamps
    Tubes and lamps
  • Audio Transformer
    Audio Transformer
  • Ref : 10791
    In Stock
    Since 2015, the MCap Supreme EVO SilverGold capacitors have been the undisputed top-of-the-line product from Mundorf. It combines all of the brand's technical strengths, such as SilverGold metallization, SUPREME and EVOLUTION winding technology and more than 30 years of experience in the manufacture of capacitors for incredible musicality.
    69,90 € 58,25 €Ex.
    In Stock
  • Ref : 10792
    In Stock
    49,00 € 40,83 €Ex.
    In Stock
  • Ref : 10785
    30,90 € 25,75 €Ex.
    In Stock
  • Ref : 10794
    In Stock
    Since 2015, the MCap Supreme EVO SilverGold and MCap Supreme EVO SilverGold OIL capacitors have been the undisputed top-of-the-line products from Mundorf. It combines all of the brand's technical strengths, such as SilverGold metallization, SUPREME and EVOLUTION winding technology, and more than 30 years of experience in manufacturing capacitors that...
    79,00 € 65,83 €Ex.
    In Stock
  • Ref : 10793
    In Stock
    79,90 € 66,58 €Ex.
    In Stock
  • Ref : 10811
    629,00 € 524,17 €Ex.
    In Stock
  • Ref : 10812
    In Stock
    529,00 € 440,83 €Ex.
    In Stock
  • Ref : 10810
    In Stock
    359,00 € 299,17 €Ex.
    In Stock
  • Ref : 10808
    219,00 € 182,50 €Ex.
    In Stock
  • Ref : 10795
    In Stock
    109,00 € 90,83 €Ex.
    In Stock
  • Ref : 10797
    In Stock
    96,00 € 80,00 €Ex.
    In Stock
  • Ref : 10798
    In Stock
    129,90 € 108,25 €Ex.
    In Stock
  • Ref : 10799
    129,00 € 107,50 €Ex.
    In Stock
  • Ref : 10800
    In Stock
    120,00 € 100,00 €Ex.
    In Stock
  • Ref : 10801
    119,00 € 99,17 €Ex.
    In Stock
  • Ref : 10803
    136,00 € 113,33 €Ex.
    In Stock
  • Ref : 10804
    144,00 € 120,00 €Ex.
    In Stock
  • Ref : 10805
    In Stock
    205,90 € 171,58 €Ex.
    In Stock
  • Ref : 10806
    163,00 € 135,83 €Ex.
    In Stock
  • Ref : 10807
    In Stock
    195,00 € 162,50 €Ex.
    In Stock
  • Ref : 1770
    In Stock
    Mundorf MCap Supreme Silver Oil are capacitors with an oil-impregnated metallized polypropylene dielectric. As the name suggests, high purity Silver is used for the capacitor coating and the winding is impregnated with a special oil.
    24,90 € 20,75 €Ex.
    In Stock
  • Ref : 1776
    In Stock
    Mundorf MCap Supreme Silver Oil are capacitors with an oil-impregnated metallized polypropylene dielectric. As the name suggests, high purity Silver is used for the capacitor coating and the winding is impregnated with a special oil that has been developed through extensive testing and listening.
    34,90 € 29,08 €Ex.
    In Stock
  • 39,90 € 33,25 €Ex.
    In Stock
  • Ref : 1779
    In Stock
    43,90 € 36,58 €Ex.
    In Stock
  • Ref : 1780
    In Stock
    65,90 € 54,92 €Ex.
    In Stock
  • Ref : 1782
    In Stock
    56,90 € 47,42 €Ex.
    In Stock
  • Ref : 1785
    In Stock
    89,90 € 74,92 €Ex.
    In Stock
  • Ref : 1784
    79,90 € 66,58 €Ex.
    In Stock
  • Ref : 1787
    In Stock
    109,00 € 90,83 €Ex.
    In Stock
  • Ref : 1789
    In Stock
    In Stock
  • Ref : 1790
    93,00 € 77,50 €Ex.
    In Stock
  • Ref : 1791
    In Stock
    205,00 € 170,83 €Ex.
    In Stock
  • Ref : 1792
    In Stock
    209,00 € 174,17 €Ex.
    In Stock
  • Ref : 1793
    In Stock
    149,00 € 124,17 €Ex.
    In Stock
  • Ref : 2181
    In Stock
    The metallization of the MCap Supreme SilverGold capacitor foil is composed of pure Silver mixed with 1% very pure Gold. Gold modifies the crystal structure of silver and maximizes its excellent electrical conductivity.
    29,90 € 24,92 €Ex.
    In Stock
  • Ref : 2174
    In Stock
    33,90 € 28,25 €Ex.
    In Stock
  • Ref : 2182
    31,50 € 26,25 €Ex.
    In Stock
  • Ref : 2183
    43,90 € 36,58 €Ex.
    In Stock
  • Ref : 2184
    In Stock
    La métallisation de la feuille du condensateur MCap Supreme SilverGold est composé d'Argent pur mélangé a 1% d'Or très pur. L'or Modifie la structure cristalline d'argent et maximise son excellente conductivité électrique.
    59,90 € 49,92 €Ex.
    In Stock
  • Ref : 2185
    40,80 € 34,00 €Ex.
    In Stock
