Selector 3 inputs 2 positions Ø6mm flat axis
Reference : 14202
4,90 €tax incl.
4,08 € tax excl.
Selector 2 positions - 3 inputs
This 3-pole x 2-position mechanical selector is used to switch several signals to a common point.
It works in both directions, the IN can also be an OUT.
The notches are relatively hard, we advise you to use it with a 40mm diameter button.
It is possible to lubricate the contacts to facilitate rotation.
Schema rotary selector connection
Inputsx3
Positionsx2
Drilling diameter9.7mmØ
width selector45 mm (with pins)
38 mm (without pins)
Shaft Diameter6mmØ
Shaft length11mm
Axis typeflat
Weight45g
