selecteur de qualité mais trop dur à tourner , même avec un boutton de 40mm de diametre
This 4-pole x3 position mechanical selector allows to switch several signals to a common point. It works in both directions, the IN can also be an OUT. The notches are relatively hard, we advise you to use it with a 40mm diameter knob. It is possible to lubricate the contacts to facilitate the rotation.
This connection pattern is split on two independent rows to form 4 Inputs.
Inputs | x4 |
Positions | x3 |
Drilling diameter | 9.7mmØ |
width selector | 45 mm (with pins) 38 mm (without pins) |
Shaft Diameter | 6mmØ |
Shaft length | 11mm |
Axis type | flat |
Weight | 45g |
Average votes 5.0 / 5 1 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
