Source selector ALPS SRRN 820c 3 positions 1 way
Reference : 6704
3,90 €tax incl.
3,25 € tax excl.
Shipping date: 18-03-2026.
Source selector ALPS SRRN 820c 3 positions 1 channel
For example, they can be mounted in a preamplifier to select the sources.
  • Maximum Power: 0.15A 12V DC
  • Lifetime: 10000 cycles
  • Made in Japan
  • Length of the axis: 18 mm (flat 12mm)
Operating temperature range
-10 ° to + 60 °
Rating (max.) / (Min.) (Resistive load)
0.15A 12V DC / 50μA 3V DC
Electrical Performance
Contact resistance (Initial performance / After lifetime)
50mΩ max. / 100mΩ max.
Insulation resistance
100MΩ min. 500V DC
Voltage proof
500V AC for 1 minute
Mechanical performance
Terminal strength
5N for 1 minute
Actuator strength
Rotational direction
1N · m
Push direction
100N
Wobble of actuator (load at the tip of shaft: 5N)
Measuring position from surface mounting
15mm
Shaft wobble (max. Value)
0.25mm max.
Applicable mounting dimension
20mm
Resistance to soldering heat
Manual soldering
350 ± 10 °, 3 (+1.0) s
Dip soldering
260 ± 5 °, 10 ± 1 s
durability
Operating life without load
10,000 cycles 70mΩ max.
Operating life with load (Load: as ratings)
10,000 cycles 100mΩ max.
Environmental Performance
Cold
-20 ± 2 ° for 96h
Dry heat
85 ± 2 ° for 96h
Damp heat
40 ± 2 °, 90 to 95% RH for 96h
https://www.audiophonics.fr/images2/5648/5648_SRRN_D_11.jpg
https://www.audiophonics.fr/images2/6704/6704_ALPS712C1WAY_1.jpg
