AUDIOPHONICS Patch cable Network RJ45 Ethernet High-End Cat 7 1m
Reference : 7175
85,00 €tax incl.
70,83 € tax excl.
Shipping date: 16-04-2025.
AUDIOPHONICS RJ45 Ethernet Cable
Cat7 1m
Audiophonics Câble Ethernet
Hand-assembled in our workshops and made from the best elements on the market, this RJ 45 patch cable provides you with the best possible interconnection quality at this price.
Equipped with the Viablue EP-7 (Copper OFC Silver Plated) Network Cable and Telegärtner MFP8 T568B connectors, it will ensure exceptional transfer quality and durability.
These cables are ideal for powering your servers with audio files, NAS, HTPC etc....
Length1m
Capacity45nF / Km
NormCat 7
Certified 600MHz-
ConductorsSilver plated OFC Copper
Section0.4mm x 7
ShieldBraid + 4 Aluminium Foil
Overall diameter8.5mm (without external sheath)
Radius of curvature34mm
Relative propagation speedAbout 0.76 C
Impedance1-100 MHz = 100 +/- 15Ω
100-250 MHz = 100 +/- 22Ω
250-600 MHz = 100 +/- 25Ω
Shielded attenuation 600MHz60dB
NormsUL444 / TIA-568-C.2
Sheath colorGray and black
ELECAUDIO SG-03
Length (m)1.0
ShieldingYes
Section (mm²)0.40
ConnectorRJ45
32 reviews
Qualité de fabrication !
La musicalité suit !
This review has been posted for AUDIOPHONICS Patch cable Network RJ45 Ethernet High-End Cat 7 1m
Simply great cable
Ordered this cable for peace of mind for quality of my streaming data. Connected between my router and my switch. Cable was great manufactured and is pretty fat, wich is good. Better than most cables cost few times more.
Cannot say nothing about sound quality, but i am pretty sure it will be hundred times better than cheap stock cable wich come with router.
Great service staff at Audiophonics and fast shipping.
Will definetly buy again.
genialissime !
Alors j'étais ultra ultra ultra septique . Après avoir changer tous les câbles d'alimentation le xlr le câble USB mi des conditionneur des câbles d'enceinte de qualité j'avais un vulgaire câble catégorie 8 a 25euro . Je me suis dis bon au vue des avis je vais essayer . Encore une fois ultra septique et non mais alors vraiment non ça fais 2h que je l'écoute et vraiment il est top top top , la qualité et génial comme toujours avec les produits Audiophonics ( leur xlr et leur coaxiaux sont génial meilleur rqp su marcher ) pour ce câble que dire hormis la chose qui m'a directement sauter au oreille , un gain dans les silences . Le son est plus ouvert , légèrement plus détaillé , les basses plus sèche et net . C'est plus calme profond les notes sont franches avec de belles armoriques . Si on met de côtes l'esthétique superbe oui ce câble ajoute un réel plus , de plus a -100e cela reste un plaisir abordable . Je pense qu'il viens dans les dernières choses a faire quand le principal et fait ( pour en profiter ) câble enceinte , câble secteur , xlr , câble USB ( ou coaxial ) et câble ethernet en dernier c est la cerise sur le gâteau , un grand bravo à Audiophonics pour nous faire de jolies produits abordable et qualitatif . Je pense qu'il y a toujours mieux mais là on atteint un sacré niveau nulle doute qu'il faille débourser le double voir le triple pour avoir un gain . Je recommande les yeux fermés . ( Et encore une fois les xlr les coaxiaux les câbles fait par Audiophonics vous pouvez y aller les yeux fermer ! Content d'avoir un site français ! Avec un bon sav un service client réactif et encore une fois de formidables produit qualitatif a bon prix !)
The name says it Hi End and the cable really is. Everything seems more mature more believable with this cable. And the impression is already straight out of the box. After some running things improve massively. Things like depth air positioning of different sources of sound on the stage are all there like the better and costly power cords do. Replaced an already good Qed ethernet that is like comparing midrange vs high end. Used between cisco 2960 and Gustard r26
Excellents
Cables installés entre mon pc et la box puis de la box à un switch Netgear (alimentations linéaires stabilisées sur le switch et la box ; alim Teddy Pardo doubles sorties) , carte son maudio . Sur mes petites lansing de bureau gains importants sur le niveau des détails ; du silence. Les musiciens et les voix gagnent énormément en réalisme et en présence. Je rachèterai ces cables sans hésiter. Aucun regret au contraire.
