Ethernet to Optical Fiber Converter (Pair) IEC Power Supply
This device converts a 10/100/1000Base-T Ethernet signal to 1000Base-SX/LX optical fiber. This allows the signal to be isolated from the rest of the Ethernet network to limit noise, while enjoying the advantages of 1000Base-SX/LX optical fibre, i. e. the greatest possible transmission distance
Reference : 13758
32,90 €tax incl.
27,42 € tax excl.
Shipping date: 24-04-2025.
Ethernet To Optical Converter
Ethernet Switch Converter 10/100/1000Base-TX to Optical 1000Base-SX/LX (Pair)
Convertisseur Switch Ethernet 10/100/1000Base-TX vers fibre Optique 1000Base-SX/LX
These devices are delivered in pairs and convert a 10/100/1000Base-T Ethernet signal to 1000Base-SX/LX optical fiber. This allows the signal to be isolated from the rest of the Ethernet network to limit noise, while enjoying the advantages of 1000Base-SX/LX optical fibre, i. e. the greatest possible transmission distance. The fiber optic port supports multimode SX and single mode LX transmission standards for distances up to 20km.
The implementation is simple. Simply connect your network source (router, switch...) to the RJ45 connector of the first converter via a twisted pair Ethernet cable and then connect the two converters together with optical fiber. Finally, simply connect the second converter to your destination device (computer) in RJ45. LED indicators indicate the operating status of the device.
Schuko / IEC power cable sold separately.
Product typeEthernet to Optical fiber converter
Input1x Ethernet RJ45 10/100/1000Base-T
Compatible Ethernet cable categoryCat5e / Cat6
Optical fiber wavelength1310nm
Distance de transmission max20km
Duplex modeFull Duplex or Half-Duplex
Supply voltage100-250V AC 50/60Hz
Dimensions140 x 110 x 30mm
Housing materialMetal
ColorGray
Length (m)N/A
ShieldingNC
Section (mm²)N/A
ConnectorOptical
ConnectorRJ45
Conductors material (Cable)Optical Fiber
Fibre
C’est le premier et le moins cher des convertisseurs optique qui fonctionne chez moi. Je ne sais pas si c’est dû à la fibre monomode. Ne pas oublier de commander une fibre monomode si vous n’en avez pas et des câbles IEC. SHUKO
This review has been posted for Ethernet to Optical Fiber Converter (Pair) IEC Power Supply
This device converts a 10/100/1000Base-T Ethernet signal to 1000Base-SX/LX optical fiber. This allows the signal to be isolated from the rest of...
