FURUTECH LAN-7 RJ45 Ethernet Cable Cat 7 Silver Plated OCC Copper 0.6m
The Furutech LAN-7 is a powerful and robust RJ45 Ethernet cable. Thus, to ensure optimal conductivity, it integrates 24AWG OCC Copper section conductors plated Silver and mounted in twisted pairs. In addition, Furutech's Alpha cryogenic processing maximizes the conductivity and stability of the signal.
Reference : 13452
99,00 €tax incl.
82,50 € tax excl.
Furutech LAN-7
Câble Ethernet RJ45 Cat 7 Cuivre OCC plaqué Argent 0.6m
Furutech LAN-7 Câble Ethernet RJ45 Cat 7 Cuivre OCC plaqué Argent 0.6m
The Furutech LAN-7 is a powerful and robust RJ45 Ethernet cable. Thus, to ensure optimal conductivity, it integrates 24AWG OCC Copper section conductors plated Silver and mounted in twisted pairs. In addition, Furutech's Alpha cryogenic processing maximizes the conductivity and stability of the signal. The cable is terminated with 24k gold plated connectors with the same Alpha treatment.
This LAN-7 Ethernet cable is a Cat 7 model. This means that it supports a bandwidth of 10 Gigabit on a frequency of 600Mhz. This Cat 7 also requires independent shielding of each pair of conductors, as well as overall shielding to limit noise and crosstalk, to which Furutech adds a third layer of shielding. It is therefore a STP type shielding with aluminium and braided copper strip. Cat 7 cables are also backward compatible with Cat 5e and Cat 6 equipment.
Product typeRJ45 Ethernet Cable
Length0.6m
Ethernet categoryCat 7
ShieldingSTP
Triple shielding : Aluminium foil and braided Copper
Cable conductor materialOCC Copper
Cable conductor platingSilver
Conductor section24AWG
TreatmentAlpha
Connectors platingGold
Cable diameter7mm
ColorBlack and blue
Length (m)0.6
ShieldingYes
Section (mm²)0.205
ConnectorRJ45
The Furutech LAN-7 is a powerful and robust RJ45 Ethernet cable. Thus, to ensure optimal conductivity, it integrates 24AWG OCC Copper section...
