GUSTARD N18 Network Switch RJ45 Optical Fiber Silver
Main picture of the GUSTARD N18
The Gustard N18 network switch features 2 RJ45 Ethernet ports and an SFP optical fiber connector. The RJ45 ethernet ports are based on 10/100/1000Base-T and 1000base-X standards, while the SFP port supports GPON/EPON protocols.
By buying this product you get 34 loyalty points
Reference : 18651
349,00 €tax incl.
290,83 € tax excl.
Shipping date: 16-07-2024.
GUSTARD N18 Network Switch 2x RJ45 1x Optical Fiber Silver
Gustard N18 network switch picture
The Gustard N18 network switch features 2 RJ45 Ethernet ports and an SFP optical fiber connector. The RJ45 ethernet ports are based on 10/100/1000Base-T and 1000base-X standards, while the SFP port supports GPON/EPON protocols. With this network switch from Gustard, you can enjoy the flexibility of RJ45 connections, but also the stability and transmission speed of a fiber optic signal. The latter can be used to connect over longer distances.
Rear view of Gustard N18 network switch
Product typeFiber optic Ethernet Network Switch
Interface2x RJ45 ethernet ports 10/100/1000Base-T and 1000base-X
1x SFP fiber optic connector
Alimentation115-230V AC 50/60Hz
Power consumption<10W
Dimensions220 x 50 x 170mm
ColorSilver
Conditionnement1x Gustard N18 network switch
1x Power supply cable
Length (m)N/A
ShieldingNC
Section (mm²)N/A
ConnectorRJ45
ConnectorOptical
Conductors material (Cable)N/A
Conductors Plating (Cable)NC
The Gustard N18 network switch features 2 RJ45 Ethernet ports and an SFP optical fiber connector. The RJ45 ethernet ports are based on...
