LINDY Ethernet Cable RJ45 S/FTP LSZH Cat.7 Copper Shielded Black 0.3m
The Ethernet network cable has a double shielded S/FTP structure and a drain wire to effectively limit interference. Its Cat.6A connectors support a bandwidth of up to 600MHz, support the 10GBase-T standard and are gold-plated for excellent conductivity and durability.
Reference : 16434
4,20 €tax incl.
3,50 € tax excl.
Shipping date: 08-05-2025.
Lindy Ethernet Cable
Lindy Câble Ethernet RJ45 S/FTP LSZH Cat.7 Cuivre Blindé Noir 0.3m
The cable is Cat.7, with full braided shielding and foil shielding (S/FTP) specially developed for use in data centers, server rooms, network racks, control cabinets, etc. These cables are manufactured and tested according to ISO/IEC 11801.
Product typeEthernet cable
Connectors2x Male RJ45 Cat.6A
Length0.3m
Cable typeCat.7
ConductorsCopper
Section26AWG
ShieldingBraided aluminum
Cable diamterØ6.5mm
SheathLSZH
Connectors bodyPolycarbonate
Connectors platingNickel
Connectors contacts platingGold
Supported bandwidth600MHz
Nominal attenuation51.4dB/100m @ 600MHz
Minimum bending radius78mm
Operating temperature range-10°C / +60°C
CertificationsRoHS, REACH, UL, California Proposition 65
Length (m)
  • 0.3
Shielding
  • Yes
Section (mm²)
  • 0.129
Connector
  • RJ45
Conductors material (Cable)
  • Copper
Conductors Plating (Cable)
  • None
The Ethernet network cable has a double shielded S/FTP structure and a drain wire to effectively limit interference. Its Cat.6A connectors support...
