installé entre les 2 elements d’une freebox. Effet imédiat par rapport àun câble standard. Câble un peu rigide.
RJ45 Cat 8.1 S/FTP LSZH Gold Plated 1m
The RJ45 Ethernet cable takes advantage of the latest Cat 8.1 standard to support bandwidth up to 2000MHz. The cable has an S/FTP structure, where the twisted pairs are shielded with an overall braided shield as well as an aluminum foil shield for each pair. The connector contacts are made of gold-plated copper to ensure very good conductivity and resistance to oxidation, while complying with Ethernet standards up to 40GBase-T. The connector also has a hook-and-loop protection that locks the cable once connected and prevents it from being pulled out. The cable is manufactured and tested according to ISO/IEC 11801 specification.
Product type | Ethernet cable |
Connectors | 2x male RJ45 |
Length | 1m |
Ethernet standard | Cat 8.1 |
Cable diameter | Ø7.5mm |
Cable sheath diameter | LSZH |
Cable conductors material | Copper |
Cable conductors section | 0.205mm² (24AWG) |
Cable shielding | Aluminium foil + braid |
Connector contacts material | Copper |
Connector contact plating | Gold |
Connector plating | Nickel |
Connector body material | Polycarbonate |
Connector dimensions | 12 x 38.5 x 17mm |
Supported bandwidth | 2000MHz |
Nominal attenuation | 24dB/30m @ 2000MHz |
Minimum radius of curvature | 60mm (2.36") |
Operating temperature | -10°C - 60°C (14°F - 140°F) |
Certification | RoHS, REACH, UL |
Color | Gray |
Length (m) |
Shielding |
Section (mm²) |
Connector |
Conductors material (Cable) |
Conductors Plating (Cable) |
Average votes 5.0 / 5 3 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Jean-Louis R.
Andoni G.
Rémy D.
