LINDY Ethernet RJ45 Cable Cat 8.1 S/FTP LSZH Gold Plated 3m
The RJ45 Ethernet cable takes advantage of the latest Cat 8.1 standard to support bandwidth up to 2000MHz. The cable has an S/FTP structure, where the twisted pairs are shielded with an overall braided shield as well as an aluminum foil shield for each pair.
Reference : 14369
29,90 €tax incl.
24,92 € tax excl.
Shipping date: 01-04-2025.
Lindy Ethernet Cable
RJ45 Cat 8.1 S/FTP LSZH Gold Plated 3m
Lindy Câble Ethernet RJ45 Cat 8.1 S/FTP LSZH Plaqué Or 1m
The RJ45 Ethernet cable takes advantage of the latest Cat 8.1 standard to support bandwidth up to 2000MHz. The cable has an S/FTP structure, where the twisted pairs are shielded with an overall braided shield as well as an aluminum foil shield for each pair. The connector contacts are made of gold-plated copper to ensure very good conductivity and resistance to oxidation, while complying with Ethernet standards up to 40GBase-T. The connector also has a hook-and-loop protection that locks the cable once connected and prevents it from being pulled out. The cable is manufactured and tested according to ISO/IEC 11801 specification.
Product typeEthernet cable
Connectors2x male RJ45
Length3m
Ethernet standardCat 8.1
Cable diameterØ7.5mm
Cable sheath diameterLSZH
Cable conductors materialCopper
Cable conductors section0.205mm² (24AWG)
Cable shieldingAluminium foil + braid
Connector contacts materialCopper
Connector contact platingGold
Connector platingNickel
Connector body materialPolycarbonate
Connector dimensions12 x 38.5 x 17mm
Supported bandwidth2000MHz
Nominal attenuation24dB/30m @ 2000MHz
Minimum radius of curvature60mm (2.36")
Operating temperature-10°C - 60°C (14°F - 140°F)
CertificationRoHS, REACH, UL
ColorGray
Length (m)3.0
ShieldingYes
Section (mm²)0.205
ConnectorRJ45
trés bien
Cable rapidement expédié par Audiophonics.
Correspond totalement a mes attentes.
Très astucieux protège languette (très fragile sur les prises RJ45)
This review has been posted for LINDY Ethernet RJ45 Cable Cat 8.1 S/FTP LSZH Gold Plated 3m
The RJ45 Ethernet cable takes advantage of the latest Cat 8.1 standard to support bandwidth up to 2000MHz. The cable has an S/FTP structure, where...
