Optical Fiber Cable SC / SC 10m
This fiber optic cable allows network data to be transmitted using light signals. This makes it possible to achieve much higher transmission rates than with a conventional RJ45 Ethernet cable with copper conductors.
Reference : 13768
12,90 €tax incl.
10,75 € tax excl.
Shipping date: 24-04-2025.
Optical Fiber Cable
SC / SC 10m
Câble Fibre Optique SC / SC 3m
This fiber optic cable allows network data to be transmitted using light signals. This makes it possible to achieve much higher transmission rates than with a conventional RJ45 Ethernet cable with copper conductors. This cable can therefore be used to connect an Internet box with a FTTH fibre source or a switch with an optical fibre connector.
Product typeOptical fiber cable
Length10m
Connectors typeSC
Propagation modeMono Mode
Conductor section9/125µm
Cable diameter2.8mm
SheathPVC (LSOH standard)
Attenuation0.38/0.24 dB/km
ColorSheath : Yellow
Connectors : Blue
Length (m)10.0
ShieldingNo
Section (mm²)N/A
ConnectorOptical
Conductors material (Cable)Optical Fiber
This fiber optic cable allows network data to be transmitted using light signals. This makes it possible to achieve much higher transmission rates...
