PANGEA PREMIER Cat7 RJ45 Ethernet Cable Silver Plated Copper Triple Shielding 0.129mm² 5m
If you have high-end audio devices connected in a network, then it is essential to use quality Ethernet cables to allow your devices to deliver their full potential. With its Premieres, Pangea offers Ethernet cables using excellent materials and a careful design, ensuring very good performance.
Reference : 13774
69,90 €tax incl.
58,25 € tax excl.
Pangea Premier
Câble Ethernet RJ45 Cat7 Cuivre Plaqué Argent Triple Blindage 0.129mm² 0.6m
The Pangea Premier incorporates 26AWG (0.129mm²) copper conductors with silver plating, ensuring very good signal conductivity. Always with a view to performance, the cable is covered with a PE sheath. In addition, each conductor is individually shielded, a prerequisite for benefiting from the Ethernet Cat 7 standard. A triple shielding is then added to minimize the negative impact of EMI / RFI interference.
Product typeRJ45 Ethernet Cable
Length5m
Connectors2x RJ45
Ethernet CategoryCat 7
Conductors materialCopper
Conductors platingSilver
Conductors section0.129mm² (26AWG)
Insulation materialPE
ShieldingTriple shielding + individual shielding for each conductor
Braided sheath colorBlack and blue
Length (m)
  • 5.0
Shielding
  • Yes
Section (mm²)
  • 0.129
Connector
  • RJ45
Conductors material (Cable)
  • Copper
Conductors Plating (Cable)
  • Silver
If you have high-end audio devices connected in a network, then it is essential to use quality Ethernet cables to allow your devices to deliver...
