PANGEA PREMIER SE Ethernet Cable RJ45 Cat7 Silver Plated Cardas Copper Triple Shielding 0.6m
If you have high-end audio devices connected in a network, then it is essential to use quality Ethernet cables to allow your devices to deliver their full potential. With its First Ethernet SE, Pangea offers cables using top-of-the-range materials and a careful design to ensure excellent performance.
Reference : 13715
44,90 €tax incl.
37,42 € tax excl.
Shipping date: 06-05-2025.
Pangea Premier SE
Pangea Premier SE Câble Ethernet RJ45 Triple Blindage Cuivre Cardas Plaquage Argent 0.6m
If you have high-end audio devices connected in a network, then it is essential to use quality Ethernet cables to allow your devices to deliver their full potential. With its Premier SE Ethernet, Pangea offers cables using top-of-the-range materials and a careful design to ensure excellent performance.
Cardas Copper & Silver Plating
The Pangea Premier SE Ethernet integrates 26AWG (0.129mm²) copper cardas conductors with silver plating to ensure maximum conductivity. Cardas Copper, developed by George Cardas, has an exceptional quality. The latter is mined in Arizona and then sent to a New England factory where it is very slowly transformed into conductors via a long process to maximize its purity. The conductors are then delivered to a second factory in order to apply the Silver plating.
PE Insulation & Triple Shielding
Always with performance in mind, the cable is covered with a PE sheath. In addition, each conductor is individually shielded, a requirement for Cat7 Ethernet standard and triple shielding is then added to minimize the negative impact of EMI / RFI interference.
Product typeRJ45 Ethernet Cable
Connectors2x RJ45
Length0.6m
Ethernet categoryCat7
Conductors materialCardas Copper
Conductors platingSilver
Conductors section0.129mm² (26AWG)
InsulationPE
ShieldingIndividual shielding of each conductor + Triple shielding
Connectors platingGold
Cable colorBlack and Gray
Length (m)
  • 0.6
Shielding
  • Yes
Section (mm²)
  • 0.129
Connector
  • RJ45
Conductors material (Cable)
  • Copper
Conductors Plating (Cable)
  • Silver
If you have high-end audio devices connected in a network, then it is essential to use quality Ethernet cables to allow your devices to deliver...
