PANGEA PREMIER SE Ethernet Cable RJ45 Cat7 Silver Plated Cardas Copper Triple Shielding 3m
If you have high-end audio devices connected in a network, then it is essential to use quality Ethernet cables to allow your devices to deliver their full potential. With its First Ethernet SE, Pangea offers cables using top-of-the-range materials and a careful design to ensure excellent performance.
Reference : 13717
89,00 €tax incl.
74,17 € tax excl.
Pangea Premier SE
Pangea Premier SE Câble Ethernet RJ45 Triple Blindage Cuivre Cardas Plaquage Argent 0.6m
If you have high-end audio devices connected in a network, then it is essential to use quality Ethernet cables to allow your devices to deliver their full potential. With its Premier SE Ethernet, Pangea offers cables using top-of-the-range materials and a careful design to ensure excellent performance.
Cardas Copper & Silver Plating
The Pangea Premier SE Ethernet integrates 26AWG (0.129mm²) copper cardas conductors with silver plating to ensure maximum conductivity. Cardas Copper, developed by George Cardas, has an exceptional quality. The latter is mined in Arizona and then sent to a New England factory where it is very slowly transformed into conductors via a long process to maximize its purity. The conductors are then delivered to a second factory in order to apply the Silver plating.
PE Insulation & Triple Shielding
Always with performance in mind, the cable is covered with a PE sheath. In addition, each conductor is individually shielded, a requirement for Cat7 Ethernet standard and triple shielding is then added to minimize the negative impact of EMI / RFI interference.
Product typeRJ45 Ethernet Cable
Connectors2x RJ45
Length3m
Ethernet categoryCat7
Conductors materialCardas Copper
Conductors platingSilver
Conductors section0.129mm² (26AWG)
InsulationPE
ShieldingIndividual shielding of each conductor + Triple shielding
Connectors platingGold
Cable colorBlack and Gray
Length (m)3.0
ShieldingYes
Section (mm²)0.129
ConnectorRJ45
RQP exelent
Essais fait entre se cable occ pl a 6% Ag pangy et le vialube ofc etamé argent et telegardner metal. Apres ecoute de trois semaine donc bien rodé ils en ressort qq difference. Pangy sais plus naturel et les instruments voix sont plus realiste. Il y a un peit plus du cpté analogique du son, par contre le grave descend un chouilla moins que sur le vialube et est moins aeré et aerien. Je vais essayer de monter des telegardner cat 7 sur les pangy car je pense que les prise du pangy sont bc moins performante dansble blindage se qui pourais etre la seul raison du grave et aeré. Bref en abaissant le bruit. Cela devrais supplenté ée vialube dans ses deux paramettre. Reste que sais une question de goût musical. Question prix ils sont tous les deux exelent. Chaque fr le vaut. J aime bien le vialube entre le modem et le filtre bonn n8. La co entre le bonn et mon streamer se fait avec un neotech neu up occ cuivre. La sais plus cher mais ont touche le ciel. Apres essai via etbpang. Il y a pas photo. Le neo depasse les deux en terme musicalité transparence naturel dynamique et aucun bruit. Extinction de note et un aigus d une douceur devtoute beauté. Le choix se faitbuniquement via le porte monnaie, quoi que pour un suppl de prix acceptable. Je pose pas la question
This review has been posted for PANGEA PREMIER SE Ethernet Cable RJ45 Cat7 Silver Plated Cardas Copper Triple Shielding 3m
If you have high-end audio devices connected in a network, then it is essential to use quality Ethernet cables to allow your devices to deliver...
