Ethernet RJ45 Cat6A Cable Silver Plated OFC Copper Shielding 3m
Viablue EP-7 RJ45 Cat4A cable guarantees extremely clean signal transmission, effectively protecting the signal from interference and distortion. Supporting the Gigabit standard for high throughput up to 1Gbps, the cable is ideal for enjoying HD audio and UHD video streams. Its flawless design incorporates 8 OFC Copper conductors with Silver plating, ensuring optimal conductivity. The latter are covered with a double shielding with aluminium foils per pair of conductors and then a braided shielding in order to drastically limit the impact of interference. In addition, the EP-7 is designed to cancel jitter, regardless of the frequency.
As for the connectors, the cable integrates Viablue's T6S models, benefiting, like the cable, from an excellent manufacturing quality. Their contacts are gold plated to maintain very good signal conductivity and oxidation resistance. Its compact design is particularly practical and the connector body uses particularly resistant materials for extended durability.
" For a relatively modest sum, the progression of the sound quality is notable. Once again, Viablue offers a model with a very favorable quality-price ratio. "
Specifications | ||
Product type | Ethernet RJ45 Cable | |
Length | 3m | |
Connectors | 2x RJ45 | |
Ethernet category | Cable : Cat7 Connectors : T6s | |
Coonductors material | Silver plated OFC Copper | |
Cross section | AWG 26/7 | |
Nominal capacity | 45nF/km | |
Impedance | 1-100MHz = 100+/-15Ω 100-250MHZ = 100+/-22Ω 250-600MHz = 100+/-25Ω | |
Shielding attenuation | Jusqu'à 600MHz > 60dB | |
External cable diameter | Ø10.5mm | |
Color | Black, gold and white |
Length (m) | 3.0 |
Shielding | Yes |
Section (mm²) | 0.129 |
Section (mm²) | 10.50 |
Connector | RJ45 |
Conductors material (Cable) | Copper |
Conductors Plating (Cable) | Silver |
