VIABLUE EP-7 Ethernet RJ45 Cat6A Cable Silver Plated OFC Copper Shielding 4m
Viablue EP-7 RJ45 Cat4A cable guarantees extremely clean signal transmission, effectively protecting the signal from interference and distortion. Supporting the Gigabit standard for high throughput up to 1Gbps, the cable is ideal for enjoying HD audio and UHD video streams.
Reference : 13864
242,99 €tax incl.
202,49 € tax excl.
Shipping date: 22-04-2025.
VIABLUE EP-7 RJ45
Viablue EP-7 RJ45 Câble Ethernet RJ45 Cat6a Cuivre OFC Plaqué Argent Blindage
Viablue EP-7 RJ45 Cat4A cable guarantees extremely clean signal transmission, effectively protecting the signal from interference and distortion. Supporting the Gigabit standard for high throughput up to 1Gbps, the cable is ideal for enjoying HD audio and UHD video streams. Its flawless design incorporates 8 OFC Copper conductors with Silver plating, ensuring optimal conductivity. The latter are covered with a double shielding with aluminium foils per pair of conductors and then a braided shielding in order to drastically limit the impact of interference. In addition, the EP-7 is designed to cancel jitter, regardless of the frequency.
As for the connectors, the cable integrates Viablue's T6S models, benefiting, like the cable, from an excellent manufacturing quality. Their contacts are gold plated to maintain very good signal conductivity and oxidation resistance. Its compact design is particularly practical and the connector body uses particularly resistant materials for extended durability.
Viablue EP-7 review by Vumetre
" For a relatively modest sum, the progression of the sound quality is notable. Once again, Viablue offers a model with a very favorable quality-price ratio. "
Product typeEthernet RJ45 Cable
Length4m
Connectors2x RJ45
Ethernet categoryCable : Cat7
Connectors : T6s
Coonductors materialSilver plated OFC Copper
Cross sectionAWG 26/7
Nominal capacity45nF/km
Impedance1-100MHz = 100+/-15Ω
100-250MHZ = 100+/-22Ω
250-600MHz = 100+/-25Ω
Shielding attenuationJusqu'à 600MHz > 60dB
External cable diameterØ10.5mm
ColorBlack, gold and white
Length (m)4.0
ShieldingYes
Section (mm²)0.129
Section (mm²)10.50
ConnectorRJ45
Viablue EP-7 RJ45 Cat4A cable guarantees extremely clean signal transmission, effectively protecting the signal from interference and distortion....
