Female 4 Poles Jack 2.5mm Socket Gold Plated
This 2.5mm female jack socket is ideal for PCB mounting and will allow you to add an efficient connectivity to a DIY project. Its contacts are gold plated and ensure a very good electrical conductivity and resistance to oxidation.
3.0 / 5
Reference : 17748
1,50 €tax incl.
1,25 € tax excl.
Shipping date: 24-04-2025.
Jack 2.5 mm Female socket
4 Poles Gold plated
Embase Jack 2.5mm Femelle 4 Pôles Plaqué Or
This female 4-poles Jack 2.5mm socket is ideal for PCB mounting and will allow you to add an efficient balanced connectivity to a DIY project. Its contacts are gold plated and ensure a very good electrical conductivity and resistance to oxidation.
Product type2.5mm female jack socket
Number of poles4
Contact platinggold
Max cable diameter (mm)N/A
Mounting typeTo weld
ConnecticFemale
Contacts number4
Close to what I need
This is a Female Socket that provides 4 connections. A 2.5mm diameter Jack plug with 4 Poles (3 isolation rings) does fit in this socket, However, only 3 Poles of the Jack plug make contact: the Pole furthest from the tip does not connect to the gold plated pin as I had expected.
This review has been posted for Female 4 Poles Jack 2.5mm Socket Gold Plated
This 2.5mm female jack socket is ideal for PCB mounting and will allow you to add an efficient connectivity to a DIY project. Its contacts are gold...
