Gold Plated 2 Poles Mono Jack 2.5mm Connector Ø4mm Silver for Sennheiser HD700 (Pair)
These 2.5mm mono jack connectors will allow you to design your own cables. This connector format is mainly used for connecting headsets.
Reference : 13611
12,90 €tax incl.
10,75 € tax excl.
Connecteur Jack 2.5mm Mono 2 Pôles Plaqué Or Ø4mm Argent (La paire)
These 2.5mm mono jack connectors will allow you to design your own cables. This connector format is mainly used for connecting headphones and here especially for the Sennheiser HD700 model which requires a connector with flat tip. They benefit from a quality design with gold-plated copper contacts. They accept cables with a diameter of up to 4mm
Product typeJack 2.5mm mono connector
Poles number2 (Signal + GND)
Max acceptable cable diameter4mm
Contacts materialCopper
PlatingGold
Total dimensions38.1 x Ø6.5mm
Max panel thickness10mm
ColorSilver
QuantitySold per pair (2 connectors)
Max cable diameter (mm)4.0
Mounting typeTo weld
ConnecticMale
Contacts number2
