Jack 2.5mm mono 2 pole gold-plated Ø4mm (Unit)
Jack mount connector for your projects and custom cables. Diameter 2.5mm connector, two poles (mono channel). The lower connector base unscrews to access the editing system. This requires soldering the cable conductors directly on the jack connectors.
Reference : 13602
4,90 €tax incl.
4,08 € tax excl.
Shipping date: 22-04-2025.
Mono Jack 2.5mm connector
Connector solder - gold plated
jack plug weld diy 2.5
The poles are gold plated for excellent conductivity and to preserve the audio signal in advanced audio use.
Package Contents
Typejack
JackMono
2.5mm
2 poles
Maximum diameterØ4mm
PlatingGold
Dimensions40mm
Ø7mm
Max cable diameter (mm)4.0
Mounting typeTo weld
ConnecticMale
Contacts number2
Jack mount connector for your projects and custom cables. Diameter 2.5mm connector, two poles (mono channel). The lower connector base unscrews to...
