Connector solder - gold plated
Jack mount connector for your projects and custom cables. Diameter 2.5mm connector, two poles (mono channel).
The lower connector base unscrews to access the editing system. This requires soldering the cable conductors directly on the jack connectors.
The poles are gold plated for excellent conductivity and to preserve the audio signal in advanced audio use.
Package Contents | |
Type | jack |
Jack | Mono 2.5mm 2 poles |
maximum diameter | Ø4mm |
Plating | Gold |
Dimensions | 40mm Ø7mm |
Color | Silver |
Max cable diameter (mm) |
Mounting type |
Connectic |
Contacts number |
Contacts Material (Connector) |
Contacts Plating (Connector) |
