Aluminium Power connector IEC OYAIDE Ø20mm
Robust and elegant, this Aluminium screw-on shell is compatible with OYAIDE IEC connectors. It was machined from the mass and then anodized. The finishes are impeccable (chamfers, threads, etc.).
Reference : 9488
17,90 €tax incl.
14,92 € tax excl.
Aluminium shell
For ⌀20mm IEC Oyaide Connector
Coque Aluminium pour connecteur IEC Oyaide
This shell is compatible with Oyaide IEC connectors from the Oyaide C-0XX range:
MaterialAnodised Aluminium
ColorSilver
CompatibilityOyaide IEC C-0XX Range
Acceptable cable diameter20mm
Internal diameter38.5mm
External diameter45mm
Length56mm
Max cable diameter (mm)
  • 20.0
Top workmanship, affordable, highly recommanded
Very high quality aluminum, you got to hold it in your hand, before you believe / realize, the great afford there have been made and put in to the product.
The aluminum shell weights a lot more, than you can figure out from the picture !
This review has been posted for Aluminium Power connector IEC OYAIDE Ø20mm
Robust and elegant, this Aluminium screw-on shell is compatible with OYAIDE IEC connectors. It was machined from the mass and then anodized. The...
