ELECAUDIO LI-07GB IEC C7 Connector Gold Plated 24k 3x5mm² Ø15mm
This IEC C7 Elecaudio LI-07GB connector is ideal for making quality power supply cables. It uses 24k gold plated copper alloy contacts of 5mm², allowing to obtain a very good conductivity and therefore an excellent quality of signal transmission.
Reference : 17787
13,90 €tax incl.
11,58 € tax excl.
Shipping date: 15-04-2025.
ELECAUDIO LI-07GB
IEC C7 Connector Gold plated 24k 3x5mm² Ø15mm
ELECAUDIO LI-07GB Connecteur secteur IEC C7 Plaqué Or 24k 3x5mm² Ø15mm
This IEC C7 Elecaudio LI-07GB connector is ideal for making quality power supply cables. It uses 24k gold plated copper alloy contacts of 5mm², allowing to obtain a very good conductivity and therefore an excellent quality of signal transmission. This connector is able to accommodate cables up to 15mm in diameter and is thus suitable for both "classic" cables and HiFi cables with a larger diameter. The connector body is made of PC 94V-0 and TPR. All the screws of this connector are made of stainless steel 304, preventing corrosion.
Connector typeIEC C7
Contact materialCopper alloy
Contact platingGold 24k
Max. cable diameterØ15mm without sleeve
Ø12mm with sleeve
Voltage / Current250V AC / 15A
Body dimensions30 x 22mm
Dimensions108*22mm
Weight36g
ScrewsPhillips screws
Material: stainless steel 304
Max cable diameter (mm)15.0
Mounting typeN/A
ConnecticFemale
ConnectorIEC C7
Rated current (A)15.0
Sans surprise
Outre une sérieuse qualité de construction, où de l'OFC étamé 1.5 mm2 à gaine silicone recouvert de gaine rilsan y fut aisément installé, le traitement de la commande fut rapide et parfait.
L'alimentation de mon Bluesound Node 2i lui dit merci.
This review has been posted for ELECAUDIO LI-07GB IEC C7 Connector Gold Plated 24k 3x5mm² Ø15mm
This IEC C7 Elecaudio LI-07GB connector is ideal for making quality power supply cables. It uses 24k gold plated copper alloy contacts of...
