ELECAUDIO PI-24GB Power Connector IEC C15 Gold Plated 24K 3μ Ø16.5mm Black
The IEC C15 reference socket PI-24GB is distinguished at first glance by its black nylon body with impeccable finish and ideal proportions. This chassis can accommodate the most sophisticated cables whose diameter is often incompatible with conventional mains sockets. With an insertion ring limiting the diameter to 16.5mm, supported by a flexible rubber cable clamp that completes the integration, the PI-24GB easily accommodates cables with a large cross-section.
4.8 / 5
Reference : 6583
17,90 €tax incl.
14,92 € tax excl.
Shipping date: 22-04-2025.
Elecaudio PI-24GB
Power connector IEC C15 Gold Plated 24K 3µ Ø16.5mm Black
Elecaudio PI-24GC Prise secteur IEC Crystal Or 24k 3µ Ø16.5mm
All metal parts, in particular the contact and earth poles, have been plated with 24k 3µ gold. This full contact surface plating is stronger and better conductive than standard gold plating and is therefore more resistant. The internal connection terminals also deserve special attention: Equipped with large fixing screws, and therefore requiring no soldering, they are capable of receiving conductors of large diameter (up to 16mm² in cross-section!) which they ensure a firm hold on a particularly large and homogeneous contact surface. Finally, we will appreciate the small diagram directly engraved in the socket, which gives information on the optimal length of cable to strip. Since you are told that nothing has been left to chance.
Connector typePower connector IEC C15 3 contacts to screw (BTR screw)
Contacts platingGold 24k 3µ
Max conductors section16mm² (Ø4.5mm)
Max cable diameterØ16.5mm
Current / Voltage16A / 250V
Total length80mm
Diameter38mm
Weight60g
Max cable diameter (mm)16.5
Mounting typeTo screw
ConnecticFemale
ConnectorIEC C15
Rated current (A)16.0
17 reviews
Iec femelle
Ressemble à une Yarbo mais moin bien fabriqué et demande des grosses sections de câble rigide ou étamés pour que le montage tienne correctement. Le contact de la prise dans l'appareil est moyen.
This review has been posted for ELECAUDIO PI-24GB Power Connector IEC C15 Gold Plated 24K 3μ Ø16.5mm Black
Conector supremo low cost
Tengo conectores que cuestan seis veces más y prefiero este.
Good plug
Easy yo handle and Solid ay barca un price
Nickel pour remplacement sur câble secteur ACTINOTE ARIA
En ayant voulu démonter le connecteur IEC d'origine de mon câble secteur ACTINOTE ARIA ancienne génération (avant le EVO avec prise schuko en bois), j'ai détérioré les visses plastique ; ça ne m'a pas trop dérangé car je comptait faire prisonnier le câble dans un lecteur MINIDISC SONY.
Cependant, après découverte de l'aspect et de la rigidité des conducteurs du câble ACTINOTE, j'ai abandonné et décidé de réhabiliter le câble secteur à ses fonctions premières.
Mon choix s'est donc porté sur cette version ELECAUDIO, identique aux fiches qu'utilisait Actinote avant de passer en 2023 à la marque Oyaide.
Son assemblage est bien conçu, attention tout de même à bien insérer les visses finales dans leur filetage, car une fois je suis passé à coté.
Il a fallu également abandonner une pièce plastique permettant de serrer le câble à l'entrée de la fiche, car une bague caoutchouc, propre à actinote et permettant le serrage de la gaine tissu avant la section, augmentait le diamètre total du câble.
Après quelques tests d'écoute, Le rendu sonore m'est apparu préservé par rapport à la version d'origine, l'aspect du câble parait plus robuste et moderne. On saluera tout de même les très bons conducteurs de l'ancienne fiche IEC Actinote (plaqués argent à l'époque) dans lesquels les conducteurs cuivre (phase/terre/neutre) étaient soudés à l'argent.
Au final, je recommande fortement ce connecteur IEC ELECAUDIO au rapport qualité prix exceptionnel ; pas étonnant qu'Actinote les avait choisis précédemment, avec un cahier des charges spécifique bien entendu (visses non métalliques, stickers et traitement/placage or des connecteurs peut être supérieur).
A fine IEC plug
Bought five of these IEC plugs and really love it. Nice price, and excellent plugs: lost of space and good screws, it's easy to connect the wires and the cable rest really secure to the plug.
The IEC C15 reference socket PI-24GB is distinguished at first glance by its black nylon body with impeccable finish and ideal proportions. This...
