ELECAUDIO PI-24GC Power Connector IEC C15 Gold Plated 24K 3μ Ø16.5mm Transparent
ELECAUDIO PI-24GC Prise Secteur IEC Crystal Or 24K 3µ Ø16.5mm
The PI-24GC IEC reference socket is distinguished at first glance by its transparent nylon body with impeccable finish and ideal proportions. This chassis can accommodate the most sophisticated cables whose diameter is often incompatible with conventional mains sockets. With an insertion ring limiting the diameter to 16.5mm, supported by a flexible rubber cable clamp that completes the integration, the PI-24GC easily accommodates cables with a large cross-section.
Reference : 6585
17,90 €tax incl.
14,92 € tax excl.
Shipping date: 23-07-2024.
Elecaudio PI-24GC
Power Connector IEC C15 Gold 24K 3µ Ø16.5mm Transparent
Elecaudio PI-24GC Prise secteur IEC Crystal Or 24k 3µ Ø16.5mm
All metal parts, in particular the contact and earth poles, have been plated with 24k 3µ gold. This full contact surface plating is stronger and better conductive than standard gold plating and is therefore more resistant. The internal connection terminals also deserve special attention: Equipped with large fixing screws, and therefore requiring no soldering, they are capable of receiving conductors of large diameter (up to 16mm² in cross-section!) which they ensure a firm hold on a particularly large and homogeneous contact surface. Finally, we will appreciate the small diagram directly engraved in the socket, which gives information on the optimal length of cable to strip. Since you are told that nothing has been left to chance...
Connector typeIEC C15 connector 3 contacts to screw (Phillips screw)
Contacts platingGold 24k 3µ
Max conductors section16mm² (Ø4.5mm)
Max cable diameterØ16.5mm
Current / Voltage16A / 250V
Total length80mm
Diameter38mm
Weight60g
Max cable diameter (mm)16.5
Mounting typeTo screw
ConnecticFemale
ConnectorIEC C15
Rated current (A)16.0
15 reviews
Excellent RQP
This review has been posted for ELECAUDIO PI-24GC Power Connector IEC C15 Gold Plated 24K 3μ Ø16.5mm Transparent
super!
facile à mettre en œuvre du bon materiel
Iscott
Très bon produit.
ELECAUDIO PI-24GC Connecteur Secteur IEC C15 Plaqué Or 24K 3µ Ø16.5mm Crystal
Ce connecteur secteur IEC est une bonne alternative à des produits similaires vendus nettement plus cher car estampillés de marques plus prestigieuses ... quoi qu’il en soit cet article est solide et bien pensé et remplira parfaitement sa fonction de manière qualitative.
Très bonne prise
Très bonne prise, facile à mettre en œuvre.
Après je ne sais pas si elle apporte une meilleure écoute mais les contacts sont de très bonnes qualités.
The PI-24GC IEC reference socket is distinguished at first glance by its transparent nylon body with impeccable finish and ideal proportions. This...
