ELECAUDIO PI-24RA IEC C15 Connector Angled Rotative Ajustable Red Copper Gold Plated Ø20mm
With their copper plated 24K gold contacts, connectors IEC PI-24RA allow the construction of extremely effective power cables.
4.9 / 5
Reference : 13653
21,90 €tax incl.
18,25 € tax excl.
Shipping date: 18-09-2026.
ELECAUDIO PI-24RA
Designed to accommodate massive audio grade cables, adjustable retaining clip can work with all cable diameter from 5 to ⌀20mm.
The contacts are gold-plated screw. The bindings support the important conductors up ⌀4.5mm diameter.
ELECAUDIO DIY Audiophile Connector for Power Cable Copper Red Copper
IEC angled rotary connector audiophile DIY self-assembly
Angled and rotatable
The connector has an ideal angled design to ensure a clean and orderly cabling even in environments with limited space.
Likewise, the cradle of the connector can be mounted according to various axes and offers 9 positions through an angle of 300 °. So we may as well ride the final right connector, 90 or even on other angles (15 ° increments).
TypeConnector assembly
connectorIEC C15
materials bodyPC 94V-0
screw materials304 Stainless Steel
contactsCopper
Plating24k
cable compatibility5 - 20mm⌀
driver compatibilityMax 4.5mm⌀
body length73mm
diameter body40mm⌀
Weight69g
Max cable diameter (mm)20.0
Mounting typeTo screw
ConnecticFemale
ConnectorIEC C15
Rated current (A)N/A
12 reviews
Très bon produit
Ce connecteur coudé réglable est solide, pratique et accepte les câbles et conducteurs de forte section. A ce niveau de prix, que demander de plus ?
This review has been posted for ELECAUDIO PI-24RA IEC C15 Connector Angled Rotative Ajustable Red Copper Gold Plated Ø20mm
très bon connecteur
réglage de l'angle par vis intelligent, permet de très facilement passer un gros cable
Pratique
Pratique pour gagner de la place derrière un meuble et bon accueil pour un elecaudio cs361 de 17 mm de diamètre.
Bonne restitution du signal.
Presque
La prise en elle même est très bien. J'adresse cet avis surtout pour le fabricant Elecaudio car il est dommage de proposer une prise coudée si grande alors qu'elle est sensée permettre de gagner un espace important. J'ai heureusement pu la bricoler à l'aide d'une ancienne référence Elecaudio PI-22G. En effet la partie iec de celle ci remplace parfaitement celle prévue permettant un gain de 8 mm environ. C'est donc dommage de ne pas directement proposer une référence plus petite constituée directement de bonnes pièces. A bon entendeur.
Cheap mais fait le job
Un peu cheap pour le tarif je trouve.
