This high-end IEC connector from ELECAUDIO,PI-26GCis distinguished at first glance by its body Aluminum and carbon plating.
The head of the connector takes advantage of an alloy Fiberglass / Nylonfor its dielectric and mechanical qualities. Contacts are copper alloynon-magnetic one-piece and cut in the mass, on which is applied a plating Gold 24K.
This new chassis allows to receive the most sophisticated cables whose diameter often proves incompatible with the conventional outlets.
Its integrated clamping ring and anti-tear reducer allow the PI-26GCto receive and maintain well-centered cables of large section.
All metal parts, including the contact and ground poles, have benefited from a plating Gold 24k over 3μ thick .
This plating over the entire surface of the contacts is more resistant and better conductor than the standard gold plating, and is thus more resistant.
The internal connection terminals also deserve attention: They are equipped with large fixing screws and therefore do not require any soldering, they are able to receive large diameter conductors, which they hold firmly on a surface of special contactvery broad.
Finally, we will appreciate the small diagram directly engraved within the socket, which gives information on the optimum length of cable to be stripped. Since you are told that nothing has been left to chance ...
Specifications:
- Body: Aluminum + Carbon plating
- Head: Fiberglass and Nylon
- IEC 3 plugs Screw-in contacts (BTR screws)
- Plating:Or 24k 3μ
- Maximum Driver Section:16mm²(4.5mm of Diameter)
- Cable Diameter: from 12.5mm to 16.5mm(up to 19.8mm without ring)
- Reducer available separately for cables of small sections (7.5 to 12.6 mm)
- Voltage / Voltage Rating: 16A / 250V
- Overall Length: 103 mm
- Diameter: 40 mm
- Weight: 110g
PI-26GC with reducer PI-26GC without gearbox
Cable schematics
