ELECAUDIO RI-07GB HiFi IEC C7 Power Plug 24k Gold Plated Black Ø16.5mm
4.5 / 5
Reference : 10455
24,90 €tax incl.
20,75 € tax excl.
These Hi-Fi power connectors where developed in France to be used with the most sophisticated power cables in the market.
The body with an exclusive and modern design was built with high pressure. His composition, 30% Fiber Glass, and 66% Nylon, can even support industrial environments, resistant to high temperatures, impacts and crushing.
We can even call these power connectors as a hybrid, an industrial quality adapted to a Hi-Fi use.
With his uniform 4mm body injection for effective vibration and resonance dampening you can use it in many ways.
Thanks to a twist grip clinch claw for cables diameters from 11.5mm to 16.5mm you can have a wide option of cable diameters to create the perfect Hi-Fi grade power cable. This clinch claw will allow the cable to stay always centered no matter the cable diameter.
All the connectors are screw Stainless steel for maximum strength.
The head of the connector also benefits of the alloy Fiberglass / Nylon for its dielectric and mechanical qualities. Contacts are copper alloy non-magnetic in one piece and machined from solid, which is applied on 24K gold plating.
Specifications:
  •    Body : 30% Glass Fiber & à 66% Nylon
  •    Screws: (Philips PH2)
  •    Plated : Gold 24k
  •    Section Maximale des Conducteurs : 15mm² (4.5mm de Diamètre)
  •    Cable diameter : de 11.5mm à 16.5mm
  •    Tension/Voltage : 16A / 250V
  •    Total length: 95 mm
  •    Diameter: 42 mm
  •    Weight: 76g
Max cable diameter (mm)16.5
Mounting typeTo screw
ConnecticFemale
ConnectorIEC C7
4 reviews
Robust and quick assembly
Very robust plug that is quick and easy to assemble thanks to the pressure plates on the conductors. The cable ring really grabs on to the cable, as well. Highly recommended.
This review has been posted for ELECAUDIO RI-07GB HiFi IEC C7 Power Plug 24k Gold Plated Black Ø16.5mm
Remplit parfaitement son rôle, elle est imposante et prévue pour du gros câble mais vu que j'ai utilisé le câble Elecaudio de 15mm c'était parfait.
Pas de réducteur fourni
J'ai finalement commandé cette fiche.
Son esthétique n'est pas très flatteur, mais elle est malgré tout de bonne qualité.
Par contre, ce type de prise est destiné à alimenter un lecteur CD, ce qui ne nécessite pas de gros cable. Pourtant elle est conçu pour un diamètre de cable de 16mm ! et difficile de défendre en dessous... C'est énorme et pas de réducteur de fourni. Pourtant il devait m'en être fourni un, mais rien dans le colis...
Donc, je dirais conception à revoir et je ne l'aurais pas acheté si d'autre modèle m'était proposé...
Toutes nos excuses pour cet oubli, nous allons vous contacter pour vous expédier les éléments manquants.
Dommage que ce connecteur soit moche et que le diamètre mini du cable soit élevé.
Bonjour,
Nous avons pris en compte votre remarque et proposerons dorénavant un réducteur avec ce connecteur.
Nous vous en ferons également parvenir un exemplaire sur simple demande.
