These Hi-Fi connectors have been developed in France to be used with the most sophisticated cables.
The body has a modern and exclusive design, which is now molded under high pressure.
Compound 30% fiberglass and 66% Nylon Strong>it can withstand industrial constraints. (High temperature, crushing, scratches).
We could consider this connector as a hybrid, an industrial grade adapted to the requirements of Hi-Fi use.
Conjugated with a thickness of 4mm Strong>this material offers it a rigidity and a resistance to the vibrations and resonances very important.
Tightening of the cable is now carried out with a rotating ring which adapts to a diameter from 13.5 to 16.5mm . (diameter reducer available in the accessories below)
The advantage of this ring in addition to a very effective tightening is that the cable remains centered and aligned whatever its diameter.
Contacts arenon-magnetic copper alloy Strong>in a single nested piece, on which is applied a plating Gold 24K
The input diameter of the contacts allows compatibility with all the cables sector of the market. (15mm²)
Features:/ Strong>
[Img-11495-left-thickbox_default]
[Img-11499-left-thickbox_default]
[Img-11498-left-thickbox_default]
Cable schematics
