FURUTECH FI-12L (R) 90° Angled IEC Connector Gold Plated Ø18mm
Reference : 14572
89,00 €tax incl.
74,17 € tax excl.
Shipping date: 24-04-2025.
FURUTECH FI-12L (G)
Very high performance IEC power plug, ideal for assembling an Audiophile high-end power cable. This superb 90° angled plug and 270° rotatable connector offers the best fit for your Hi-Fi devices. In addition to its Gold-plated Copper contacts, the FI-12L also benefits from the proprietary FURUTECH Alpha α Anti-magnetism treatment.
The FI-12L model also takes advantage of the patented "Floating Field Damper System" technology which, according to the manufacturer, almost completely eliminates the creation of micro zones of magnetic and electrostatic turbulence inside the connector. Such perturbations may appear when current flows near conductive pieces of the structure in regular connectors (metal fixing screws, cable clamping elements, etc...) These “floating” micro force fields conflict with a much more powerful primary magnetic flux and may cause signal instability or distorsion. FURUTECH addresses this issue by connecting all the metal parts concerned to one another before connecting them to the ground to get rid of any undesired field.
Its body combines nylon and fiberglass composite material, incorporating carbon particles, which shows extreme resistance to shocks, electric arcs and high temperatures.
Compatible with cables between 6.6mm and 18mm diameter.
TypePower plug
IEC 15
Contacts
Pure Copper
Gold plated
TreatmentAnti-Magnetism FURUTECH Alpha α
IEC connector rotation270°
Case materialsNylon & fiberglass
Diameter supported6.6 - 18mm
Voltage / intensity250V/16A
125V/16A
Max cable diameter (mm)18.0
Mounting typeTo screw
ConnecticFemale
ConnectorIEC C15
Rated current (A)16.0
4 reviews
bonne qualité
This review has been posted for FURUTECH FI-12L (R) 90° Angled IEC Connector Gold Plated Ø18mm
Parfait
Prise coudée de très bonne qualité, avec une FI48or sur un SP1100 ça marche très bien sur un R7.
Excellente fiche
Fiche robuste, système de serrage avec mâchoires, extrêmement efficace et moins destructeur qu'une vis de serrage.La fiche tient parfaitement.En ce qui est du rendu sonore, elle c 'est plutôt naturel et n'apporte aucune dureté.Je recommande si vous cherchez une fiche iec coudée de bonne facture qui supporte les démontages, même avec de la grosse section (le FP-3TS762 entre autre )
Très bon connecteur
Déjà acheté dans la même marque et avec les mêmes caractéristiques des connecteurs coudés schuko, ce connecteur IEC coudé présente les mêmes qualités. La prise est de grande qualité et s'insère sans le moindre flottement dans l'appareil. Les câbles tiennent parfaitement bien dans le boitier qui est réglable dans son orientation. Tout simplement, un très bon produit.
