FURUTECH FI-12L (R) Angled IEC Connector Rhodium Plated Ø18mm
By buying this product you get 30 loyalty points
Reference : 10612
109,00 €tax incl.
90,83 € tax excl.
Shipping date: 16-09-2026.
FURUTECH FI-12L (R)
Very high performance IEC power plug, ideal for assembling an Audiophile high-end power cable. This superb 90° angled plug and 270° rotatable connector offers the best fit for your Hi-Fi devices. In addition to its Rhodium-plated Copper contacts, the FI-12L also benefits from the proprietary FURUTECH Alpha α Anti-magnetism treatment.
The FI-12L model also takes advantage of the patented "Floating Field Damper System" technology which, according to the manufacturer, almost completely eliminates the creation of micro zones of magnetic and electrostatic turbulence inside the connector. Such perturbations may appear when current flows near conductive pieces of the structure in regular connectors (metal fixing screws, cable clamping elements, etc...) These “floating” micro force fields conflict with a much more powerful primary magnetic flux and may cause signal instability or distorsion. FURUTECH addresses this issue by connecting all the metal parts concerned to one another before connecting them to the ground to get rid of any undesired field.
Its body combines nylon and fiberglass composite material, incorporating carbon particles, which shows extreme resistance to shocks, electric arcs and high temperatures.
Compatible with cables between 6.6mm and 18mm diameter.
TypePower plug
IEC 15
ContactsPure Copper
Rhodium plated
TreatmentAnti-Magnetism FURUTECH Alpha α
IEC connector rotation270°
Case materialsNylon & fiberglass
Diameter supported6.6 - 18mm
Voltage / intensity250V/16A
125V/16A
Max cable diameter (mm)18.0
Mounting typeTo screw
ConnecticFemale
ConnectorIEC C15
Rated current (A)16.0
3 reviews
Top !
Juste achetée pour le fun, pour avoir une belle prise...
Et là, ENORME surprise....Branchée sur mon DAC Mark Levinson N360S...Un changement radical au niveau son. J'ai écouté mes CD jusqu'à 3h du matin...Et je redécouvre tous mes CD du fur et à mesure....Produit que je recommande fortement....
This review has been posted for FURUTECH FI-12L (R) Angled IEC Connector Rhodium Plated Ø18mm
Très bien
Excellente prise qui se démonte complètement pour facilité le montage de gros câble (rigide sur une petite longueur) dans mon cas le YARBO SP-1100PW, très satisfait.
Efficaces
A résolu un problème de place à l'arrière de mes équipements. Accepte de gros câbles peu souples donc est très utile : yarbo 7000.
Côté son, rien à redire, ça marche très bien.
