FURUTECH FI-28 (R) IEC Connector Plated Rhodium Ø17.5mm
By buying this product you get 42 loyalty points
Reference : 4718
149,00 €tax incl.
124,17 € tax excl.
IEC female plug very high performance, ideal for the construction of an Audiophile mains cable without compromise. In addition to its contacts Copper plated Rhodium , the FI-28 also benefits from the proprietary anti-magnetism treatment FURUTECH Alpha α which involves 2 steps:
1- Cryogenization of metals by -250 ° C with the aid of liquid nitrogen in order to consolidate their molecular structure and to improve their conductivity significantly.
2- Submission of these same metals to a powerful magnetic field created by means of magnets arranged in rings and whose attraction force is constantly controlled so as to leave no residual magnetic at the end of the treatment.
The FI-28 also uses the patented technology "Floating Field Damper System"which makes it possible to eliminate almost totally the creation of micro magnetic and electrostatic turbulence zones internally of the plug, perturbations generated by the passage of the current to prox(metal fastening screws, cable clamping elements, etc.). These "floating" field micro-fields conflict with the much more powerful primary magnetic flux generated by the current flow through the cable and the connectors, thereby inducing a form of electrical resistance detrimental to conductivity, generate a form of distortion. FURUTECH succeeds in controlling these phenomena by connecting all the metallic parts concerned together with a conductor charged with bringing all these undesirable energies to the earth.
Its body in material compositenylon and fiberglassit demonstrates extreme resistance to shocks, electric arcs and high temperatures.
The conductors are fixed by means of3 screws (2 poles + ground) marked with color code and whose firmness of maintenance, obtained thanks to the technology FURUTECH "Wire Clamp", makes it possible to exclude any risk of tearing or accidental deterioration of the cable, while significantly improving the contact surface.
Compatible with cables in the section is included between 6 and 17.5mm in diameter .
Features:
  • contactsPure Copper Plated Rhodium
  • Anti-magnetism treatment FURUTECH Alphaα.
  • Technology Owner "Floating Field Damper System"
  • Nylon & Fiberglass Body
  • Screw plug (3 screws marked with color code)
  • Patented "Wire Clamp" Cable Tightening Technology (Improved Contact Area of ​​17%)
  • Compatible with Cables of Diameter between 6 and 17.5mm
  • Body Length: 76.2mm
  • Body Diameter: 39.6mm
  • 250V / 10A - 125V 15A
https://www.audiophonics.fr/images2/4718_FURUTECH-FI28R_1.jpg
https://www.audiophonics.fr/images2/4718_FURUTECH-FI28R_3.jpg
https://www.audiophonics.fr/images2/4718_FURUTECH-FI28(R)_2.jpg
https://www.audiophonics.fr/images2/4718_FURUTECH-FI28(R)_3.jpg
https://www.audiophonics.fr/images2/4718_FURUTECH-FI28(R)_4.jpg
https://www.audiophonics.fr/images2/4718_FURUTECH-FI28(R)_5.jpg
https://www.audiophonics.fr/images2/4718_FURUTECH-FI28(R)_6.jpg
Max cable diameter (mm)17.5
Mounting typeTo screw
ConnecticFemale
ConnectorIEC C15
Rated current (A)15.0
3 reviews
Warm and safe sound
This connector has quite a warm sound and no sharp edges once it's burned in. If you want that kind of tonality is great. Oyaide C-004 has much cleaner edges and quicker transients, more resolution overall, but it is much leaner in tonality.
FURUTECH FI-C15 NCF (R) is a great alternative. Not as warm and fluid, but cleaner and more open than this one, and at a lower price too.
 (3)
This review has been posted for FURUTECH FI-28 (R) IEC Connector Plated Rhodium Ø17.5mm
attention au mariage !
Sur mon système, j'ai préféré la 28 en gold qui me parait plus homogène, les aigus et haut médiums sont très définis sans être agressif mais cela se fait légèrement au détriment du grave, si vous recherchez à amener un peu plus de clarté dans votre écoute alors c'est le bon choix.
Fiche rhodium excellent
excellent fiche secteur en rhodium. monté sur un câble secteur on gagne en détaille, clarté, dynamique génial.
Pas vraiment différence entre la version NCF et le normale vue les connecteur son identique cuivre pur plaqué Rodhium. Pour 100€ plus on vous rajoute de la poudre NFC mais pour quel quantité dans le boitier en Nylon c'est un peu cher donné. Dommage
 (3)
