FURUTECH FI-31 (G) IEC C19 US Connector Gold Plated 20A Ø20mm
This IEC C19 connector is dedicated to making high-end audiophile mains cables. It has high performance 20A components and has 2 poles + 1 ground. It is compatible with cable diameters from 6.6mm to 20mm and has very good performance: 20A/125V and 16A/250V.
By buying this product you get 42 loyalty points
Reference : 2103
149,00 €tax incl.
124,17 € tax excl.
Shipping date: 25-04-2025.
FURUTECH FI-31 (G)
IEC C19 US connector gold plated 20A Ø20mm
FURUTECH FI-32 (R) Connecteur IEC C19 20A Plaqué Rhodium US Ø18mm
This IEC C19 connector is dedicated to making high-end audiophile mains cables. It has high performance 20A components and has 2 poles + 1 ground. It is compatible with cable diameters from 6.6mm to 20mm and has very good performance: 20A/125V and 16A/250V. The conductors are made of pure alpha copper and are gold plated, which provides very strong corrosion resistance.
SpEcifications
Product typeIEC PLUG High performances
Performance20A/125V
16A/250V
Connectors2 poles + earth (US Standard)
CompatibilityCables from 6.6mm to 20mm
ConductorsGold plated copper α (Alpha)
Ground disconnection systemJumper
MaterialNylon/ Fiberglass
ShellPolycarbonate
DimensionsDiameter : 38mm
Body length : 48.2 mm
Total Length : 72mm
Max cable diameter (mm)20.0
Mounting typeTo screw
ConnecticFemale
ConnectorIEC C19
Rated current (A)20.0
This IEC C19 connector is dedicated to making high-end audiophile mains cables. It has high performance 20A components and has 2 poles + 1 ground....
