FURUTECH FI-32 (R) IEC C19 20A Plug Rhodium Plated US Ø18mm
This IEC C19 connector is dedicated to making high-end audiophile mains cables. It has high performance 20A components and has 2 poles + 1 ground. It is compatible with cable diameters from 6.6mm to 18mm and offers very good performance: 20A/125V and 16A/250V.
By buying this product you get 60 loyalty points
Reference : 17477
209,00 €tax incl.
174,17 € tax excl.
Shipping date: 06-05-2025.
FURUTECH FI-32 (R)
IEC C19 PLUG 20A Rhodium Plated US Ø18mm
FURUTECH FI-32 (R) Connecteur IEC C19 20A Plaqué Rhodium US Ø18mm
This IEC C19 plug is dedicated to making high-end audiophile mains cables. It has high performance 20A components and has 2 poles + 1 ground. It is compatible with cable diameters from 6.6mm to 18mm and offers very good performance: 20A/125V and 16A/250V. The conductors are made of pure alpha copper, they are plated in rhodium, a chemically neutral component, well-known for its extreme resistance and providing a very strong resistance to corrosion.
SpEcifications
Product typeIEC PLUG High performances
Performance20A/125V
16A/250V
Connectors2 poles + earth (US standard)
CompatibilityCables from 6.6mm to 18mm
ConductorsPure copper  α (Alpha)
Ground disconnection systemJumper
MaterialNylon/ fiberglass
ShellPolycarbonate
DimensionsDiameter : 38mm
Length of body : 48.2 mm
Total length : 74 mm
Max cable diameter (mm)
  • 18.0
Mounting type
  • To screw
Connectic
  • Female
Connector
  • IEC C19
Contacts Material (Connector)
  • Copper Alloy
Contacts Plating (Connector)
  • Rhodium
Rated current (A)
  • 20.0
This IEC C19 connector is dedicated to making high-end audiophile mains cables. It has high performance 20A components and has 2 poles + 1 ground....
