FURUTECH FI-46 NCF (G) Gold Plated Copper IEC C15 Connector Alpha Treatment NCF Ø20mm
The Furutech FI-46 NCF (G) is part of the brand's range of connectors incorporating the NCF material and benefiting, as with all Furutech products, from an excellent quality design. It uses high quality components, carefully selected for their performance in audiophile use.
4.0 / 5
Reference : 13888
239,00 €tax incl.
199,17 € tax excl.
Shipping date: 08-04-2025.
Furutech FI-46 NCF (G) Connecteur IEC C15 Cuivre Plaqué Or Traitement Alpha NCF
The Furutech FI-46 NCF (G) is part of the brand's range of connectors incorporating the NCF material and benefiting, as with all Furutech products, from an excellent quality design. It uses high quality components, carefully selected for their performance in audiophile use. The connector contacts are made of pure gold-plated copper with Alpha treatment (α). The latter consists of a first cryogenization step and a second demagnetization step, which increases the conductivity of the contacts.
The connector body is made of Nylon and Fiberglass as well as NCF (Nano Crystal² Formula), an anti-resonance material. The latter uses a crystalline material with two active properties. The first is to generate negative ions to eliminate static electricity and the second is to convert thermal energy into infrared. Furutech combines NCF with ceramic nano-particles and carbon powder for a piezoelectric damping effect. The connector shell is made of anodized and brushed aluminum, improving both the durability of the connector and limiting the impact of interference on the signal. The connector also uses an efficient cable holding system, using a metal clamp.
Floating Field Damper System
The magnetic field running through a cable and its connector create a magnetic and electrostatic field around them several times a second. This magnetic field induces current leakage and electrical potential in small components such as screws that hold the connector body and must be made of metal for effective clamping. Current leaks in these components create a magnetic field floating around them and interfering with the larger magnetic field of the cable and connector and generating distortion and noise.
The Floating Field Damper System solves this problem by grounding these metal parts. All the different metal parts of the connector are connected to each other and shunt the generated electrical potentials to ground. This significantly reduces noise by reducing distortion for extremely clean and stable energy transfer.
Product typeIEC C15 Connector
Contacts materialPure Copper, Alpha Treatment (α)
Contacts platingGold
Insulation technologyFloating Field Damper System
Connector body materialsNylon / Fiberglass and NCF
Damping materialCeramic nanoparticles and carbon powder for piezoelectric damping
Connector shell materialAnodized and brushed Aluminium
Min / Max Cable diameterMin : 6mm
Max : 20mm
Connector dimensionsBody : 52 x Ø39.8mm
Total length: 80.3mm
Cable tightening systemMetal clamps
Weight110g
Max cable diameter (mm)20.0
Mounting typeN/A
ConnecticFemale
ConnectorIEC C15
Rated current (A)N/A
4 reviews
Le Must
Les meilleur prise de la gamme de chez Furutech .
Transparente ,silence, placement des instruments, autorité....
Meilleur que R .Charlin , viborg et autre. ( qui sont aussi de très bonne factures )
A monté sur câble de la même marque N 32 uniquement
FI -50 NCF rhodium tendance à faire brillé le système mais
l'ouverture et profondeur grandiose.
FI- 46 NCF le TOP !!!!!!!!!!
FI -E38 G donne une sonorité chaude aigu soigneux
FI -E11 Cu donne un son dynamique ,pétillant et poil
coloré ( comme lors du rodage de tube )
Mon ensemble audio est hybrid.
This review has been posted for FURUTECH FI-46 NCF (G) Gold Plated Copper IEC C15 Connector Alpha Treatment NCF Ø20mm
EXCELLENTE PRISE / alternative à la FI50ncf
J'ai acheté plusieurs de ces prises en remplacement de FI50ncf rhodium, ces dernières faisaient monter mon système, c'était fatiguant et je ne prenais plus de plaisir. Une par une j'ai remplacé les fi50 par des fi 46, même dynamique, ouverture, chaleur, j'ai retrouvé enfin du plaisir à l'écoute. Je recommande chaudement.
Very difficult to work with
My hands are exhausted and torn up from trying to get these connectors to work with a Furutech stiff cable with a 16mm diameter. Very difficult to manage.
Not so sweet
I bought this connector with FI-E48. FI-46 is made from satinised aluminum and is light, FI-E48 is made from some steel and chrome coated and is much heavier. Look absolutely different. Inside metal case is thin plastic, where in this thin plastic we screw screws that connect both sides of plug. Very delicate solution if you use thick and rigid cable. In FI-46 additionally we have very small space for unisolated cable, about 1cm, when you use thick cabel, mounting is very difficult. I bought once and never more even if it sound like divine.
The Furutech FI-46 NCF (G) is part of the brand's range of connectors incorporating the NCF material and benefiting, as with all Furutech...
