FURUTECH Fi-48 NCF (AG) Silver Plated Copper IEC C15 Connector Alpha Treatment NCF Ø20mm
The Furutech FI-48 NCF (AG) is part of the brand's range of connectors incorporating the NCF material and benefiting, as with all Furutech products, from an excellent quality design. It uses high quality components, carefully selected for their performance in audiophile use.
By buying this product you get 50 loyalty points
Reference : 13894
257,00 €tax incl.
214,17 € tax excl.
Furutech FI-48 NCF (AG) Connecteur IEC C15 Cuivre Plaqué Rhodium Traitement Alpha NCF Ø20mm
The Furutech FI-48 NCF (AG) is part of the brand's range of connectors incorporating the NCF material and benefiting, as with all Furutech products, from an excellent quality design. It uses high quality components, carefully selected for their performance in audiophile use. The connector contacts are made of pure Silver-plated pure copper with Alpha treatment (α). The latter consists of a first cryogenization step and a second demagnetization step, which increases the conductivity of the contacts.
The connector body is made of Nylon and Fiberglass as well as NCF (Nano Crystal² Formula), an anti-resonance material. The latter uses a crystalline material with two active properties. The first is to generate negative ions to eliminate static electricity and the second is to convert thermal energy into infrared. Furutech combines NCF with ceramic nano-particles and carbon powder for a piezoelectric damping effect. The connector shell is made of non-magnetic SUS303 Steel, improving both the durability of the connector and limiting the impact of interference on the signal. The connector also uses an efficient cable holding system, using a metal clamp.
Floating Field Damper System
The magnetic field running through a cable and its connector create a magnetic and electrostatic field around them several times a second. This magnetic field induces current leakage and electrical potential in small components such as screws that hold the connector body and must be made of metal for effective clamping. Current leaks in these components create a magnetic field floating around them and interfering with the larger magnetic field of the cable and connector and generating distortion and noise.
The Floating Field Damper System technology solves this problem by grounding these metal parts. All the different metal parts of the connector are connected to each other and shunt the generated electrical potentials to ground. This significantly reduces noise by reducing distortion for extremely clean and stable energy transfer.
Product typeIEC C15 Connector
Contacts materialPure Copper, Alpha Treatment (α)
Contacts platingSilver
Insulation technologyFloating Field Damper System
Connector body materialNylon / Fiberglass and NCF
Damping materialCeramic nanoparticles and carbon powder for piezoelectric damping
Connector shell materialNon Magnetic SUS303 Stainless Steel
Min / Max cable diameterMin : 6mm
Max : 20mm
Connector dimensionsBody: 44 x Ø34.5mm
Total length: 80.3mm
Cable tightening systemMetal clamps
Weight186.4g
Max cable diameter (mm)
  • 20.0
Mounting type
  • N/A
Connectic
  • Female
Connector
  • IEC C15
Contacts Material (Connector)
  • Copper
Contacts Plating (Connector)
  • Silver
Rated current (A)
  • N/A
2 reviews
Excellente prise
Excellent compromis entre la FI-46 NCF (G) à la sonorité plus chaude de l'or, et la FI-48 NCF Rhodium, dont le plaquage favorise un peu les aigus. Dans mon cas, elle vient compléter de la meilleure des façon une schuko 50 NCF, plaquée rhodium. L'utilisation de deux 50 NCF ne me convenait pas, car mettant trop en avant les aigus, le plaquage argent est pour moi plus neutre, pour compléter une prise rhodium.
Comparé à une FI-46 or, c'est bien plus ouvert et plus résolu dans l'aigu, tout en gardant le même charme d'écoute.
This review has been posted for FURUTECH Fi-48 NCF (AG) Silver Plated Copper IEC C15 Connector Alpha Treatment NCF Ø20mm
La qualité à un malheureusement un prix
Excellent connecteur, un peu plus de subtilité qu'une fi46, meilleur scène sonore, évidemment ce n'est pas le jour et la nuit mais sur un bon système on voit la différence. Associé à un câble furutech 55, je me régale.
The Furutech FI-48 NCF (AG) is part of the brand's range of connectors incorporating the NCF material and benefiting, as with all Furutech...
