FURUTECH FI-68 (R) EMI Filter IEC Connector Rhodium Plated Ø15.5mm
IEC female plug very high performance, ideal for the construction of an Audiophile mains cable without compromise. In addition to its Rhodium Plated Copper contacts, the FI-68 also benefits from the FURUTECH Alpha α anti-magnetism treatment. The FI-68 is a sophisticated, luxuriously finished and finished power supply filtering unit that eliminates many problems caused by contaminated power lines. Efficiency against electromagnetic disturbances (EMI) propagated by radiation or conduction.
By buying this product you get 60 loyalty points
Reference : 10609
209,00 €tax incl.
174,17 € tax excl.
The modelFI-68 also uses the patented "Floating Field Damper System", which virtually eliminates the creation of micro-magnetic and electrostatic turbulence zones inside the plug, disturbances caused by current flows near certain (metal fastening screws, cable clamping elements, etc.). These "floating" force field microscopes conflict with the much more powerful primary magnetic flux generated by the passage of the current to generate a form of distortion. FURUTECH succeeds in controlling these phenomena by connecting all the metallic parts concerned together with a conductor charged with bringing all these undesirable energies to the earth.
Its body combines two materials "actifs ": particles of nanometric size made of ceramic and carbon powder and a compositenylon and fiberglass, which demonstrates extreme resistance to shocks, electric arcs and high temperatures.
Compatible with cables in the section is between 6.6mm and 15.5mm in diameter.
Characteristics :
  • Contacts Pure Copper Rhodium Plated
  • Anti-magnetism treatment FURUTECH Alpha α
  • Floating Field Damper System
  • Nylon & Fiberglass Body
  • Screw-in plug (3 screws marked with col- lector code)
  • Compatible with cables of Diameter between 6.6 and 15.5mm
  • 250V / 15A - 125 / 15A
Max cable diameter (mm)15.0
Mounting typeTo screw
ConnecticFemale
ConnectorIEC C14
Rated current (A)15.0
IEC female plug very high performance, ideal for the construction of an Audiophile mains cable without compromise. In addition to its Rhodium...
