FURUTECH FI-8.1(G) Gold Plated IEC C7 Connector Alpha Treatment Ø10.5mm
The Furutech FI-8.1(G) is a high-end connector with a high quality design based on gold-plated copper alloy contacts and Alpha treatment. Its compact design is perfect for use in tight spaces.
Reference : 13862
64,90 €tax incl.
54,08 € tax excl.
Furutech FI-8.1(G)
Furutech FI-8.1(G) Connecteur IEC C7 Plaqué Or Traitement Alpha Ø10.5mm
Benefiting from a high quality design, the IEC C7 Furutech FI-8.1 connector incorporates high-performance components to ensure excellent conductivity. Thus, the connector contacts are made of a Copper Alloy with gold plating and α (Alpha) treatment. This treatment consists of a first cryogenization step and a second demagnetization step, which increases the conductivity of the contacts.
The connector body is made of Nylon. In addition, this FI-8.1(G) incorporates a brand new cable holding and resonance control system, all in a more compact format ideal for use in confined spaces.
Product typeIEC C7 Connector
Contacts materialCopper alloy
Contacts platingGold
Contacts treatmentα (Alpha)
Shelle materialNylon
Min / Max cable diameter5mm / 10.5mm
Max cable section2mm² / 14AWG
Connection typeTo solder
Dimensiosn14.5 x 21.5 x 51.2mm
Weight17g
Max cable diameter (mm)10.5
Mounting typeTo weld
ConnecticFemale
ConnectorIEC C7
Rated current (A)N/A
The Furutech FI-8.1(G) is a high-end connector with a high quality design based on gold-plated copper alloy contacts and Alpha treatment. Its...
