FURUTECH FI-8.1(R) NCF Rhodium Plated IEC C7 Connector NCF Alpha Treatment Ø10.5mm
The NCF Furutech FI-8.1 is a high quality IEC C7 connector with Rhodium plating, Alpha treatment and NCF, ensuring very good performance. The connector also benefits from a compact design making it ideal for use in confined spaces.
Reference : 13861
65,00 €tax incl.
54,17 € tax excl.
Furutech FI-8.1 NCF
Furutech FI-8.1 NCF Connecteur IEC C7 Plaquage Rhodium NCF Traitement Alpha Ø10.5mm
With its high quality design, the Furutech FI-8.1 uses high quality materials to ensure excellent performance. Thus, the connector contacts are made of a Copper Alloy with Rhodium plating and α (Alpha) treatment. This treatment consists of a first cryogenization step and a second demagnetization step, which increases the conductivity of the contacts.
The connector body is made of Nylon and Fiberglass as well as NCF (Nano Crystal² Formula), an anti-resonance material. The latter uses a crystalline material with two active properties. The first is to generate negative ions to eliminate static electricity and the second is to convert thermal energy into infrared. Furutech combines NCF with ceramic nano-particles and carbon powder for a piezoelectric damping effect.
In addition, this FI-8.1 incorporates a brand new cable holding and resonance control system, all in a more compact format ideal for use in confined spaces.
Product typeIEC C7 Connector
Contacts materialCopper alloy
Contacts platingRhodium
Contacts treatmentα (Alpha)
Shell materialNylon, Fiberglass, NCF
Min / Max Cable diameter5mm / 10.5mm
Max conducteur section2mm² / 14AWG
Connection typeTo solder
Dimensions14.5 x 21.5 x 51.2mm
Weight17g
Max cable diameter (mm)10.5
Mounting typeTo weld
ConnecticFemale
ConnectorIEC C7
Rated current (A)N/A
The NCF Furutech FI-8.1 is a high quality IEC C7 connector with Rhodium plating, Alpha treatment and NCF, ensuring very good performance. The...
